Getting your phone unlocked - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Smartphone and Tablet Computing including Android, Blackberry and iOS devices
Old 2007-01-17, 05:37 PM   #1
beanagee1
Default Getting your phone unlocked
I have a Motorola Razr phone on the Fido network. I am going to India for a few week next month so I explored the possibility of purchasing a pre-paid SIM card in India. In order to use a SIM card from India I needed an unlocked phone. Fido informed me that the phones are locked and they will charge $200 to unlock it. It did a search on Craigslist and found a number of locals willing to do it for $20. It worked, at least in theory, but the true test will be when I try to use it in India next months.
You should ask them to show you that the phone is unlocked by inserting a SIM card from someone other than your current provider.
beanagee1 is offline
Old 2007-01-19, 07:31 PM   #2
Paolo
Actually, Fido mis-quoted you, their price is actually $250 plus tax.
Beware of the individuals who advertize to unlock it for something cheap like $40 or $20 bucks, because you dont want what happened to my friend, the guy had to open up the phone, cut away at one of the shields, and connect some wires to some test points, and in doing such, he broke something inside the phone and the phones warranty had become permanently voided. his $400 razr turned into a useless/weightless paper weight.
Paolo is offline
Old 2007-02-02, 08:56 AM   #3
bsharwood
Paolo's story is likely a rarity. I know in Toronto you can go do one of those places around Yonge and Dundas and almost all of them will do it for between $20 and $40. It should be a software thing, so they shouldn't be opening up your phone and clipping wires.
bsharwood is offline
Old 2007-02-03, 02:14 PM   #4
Paolo
its actually not as rare as you think... the software thing can flash your phone with software which is not carrier specific, also voiding warranty when you need to take it in for service.
Paolo is offline
Old 2007-02-04, 02:35 PM   #5
MontrealPNE
I bought an unlocked phone from TigerDirect.ca. It's been working fine for 6 months.
MontrealPNE is offline
Old 2007-02-04, 08:05 PM   #6
Paolo
Wait till something goes wrong with it.
Paolo is offline
Old 2007-02-04, 10:04 PM   #7
bluntman
Yes, flashing your phone will void it's warranty with the carrier. However, if you are going to be using your phone in another country, it is a good idea to have it unlocked. My mom had her Sony phone unlocked for use during our recent trip to the Philippines. We popped in a SIM as soon as we got there and everything worked well.
bluntman is offline
Old 2007-02-05, 04:50 AM   #8
bsharwood
I agree with bluntman, it will void your warranty if you unlock your phone, although if you buy unlocked from TigerDirect or such, they'll probably help you out. The amount of money you can save by unlocking your phone and using another sim in another country will drastically outweigh even buying a new phone. At the rates that Rogers (and Bell too) charge it's about 30 minutes of use in Europe and you'll have enough money to buy a new phone.
Old 2007-02-05, 08:22 AM   #9
bluntman
The phone I currently use (O2 Xda Neo) and my previous phone (Motorola E1000) are both unlocked, both bought locally. I haven't had any problems with them, just be don't do anything stupid while handling them and you'll be fine.
bluntman is offline
Old 2007-02-13, 04:37 PM   #10
bsharwood
Try getting your phone fixed under warranty from Rogers, even if you are covered. You'll end up spending about as much time and money as you would if you were to have broken your phone voiding your warranty.
Old 2007-02-13, 06:44 PM   #11
Rexxer
thats because its impossible to try any common sense conversations with Rogers. I have about a year term left on my cell with Rogers and will be going to Bell immediatly. Rogers have been nothing but headaches. I wish I could save everyone the agony of ever sending a dime to them
Rexxer is offline
Old 2007-02-15, 10:12 PM   #12
Paolo
sorry to hear about your loss. Not the loss that your leaving rogers, but the fact that your going to Bellus.. With jacked up SAF Fee's and a bad reputation.
Paolo is offline
