ATSC DVR & PVR Recorders - Page 13 - Canadian TV, Computing and Home Theatre Forums
Old 2009-08-27, 01:28 PM   #181
rocknroller
Thumbs up Thank you members!
Dear ddDave & mr weather....Thanks for your input. What I am attempting to do is receive digital signal on the Sony XBR 40" set and to tune the digital channels, I must have an ATSC tuner...isn't that correct?
Now.... the converter boxes that everyone got via the FCC simply reconverted the digital signals back to analog so that the older sets with NTSC tuners could receive them (at least that is my understanding).... so I want to get a digital dvd recorder with an ATSC tuner and use one of the digital inputs on the set to receive the signal from the dvd recorder tuner. If I do this I will be able the receive both analog and digital signals by simply using the remote to select the input....either through the NTSC tuner in the set, or via ATSC tuner in the dvd recoder/player unit for the digital signals.
Am I making this unduly complicated, and is there a better or simpler way to accomplish this? If so, please let me know.
Locating a really good dvd recorder/player ATSC unit is my next step so I will try to locate the Panasonic unit per mr weather's advice but hopefully there are more choices available. If so, anyone who might suggest a source for the dvd recorder/player w/ATSC tuner, would be greatly appreciated.
Thanks again to everyone for your assistance and kindness.....rocknroller
rocknroller is offline
Old 2009-08-27, 01:38 PM   #182
stampeder
rocknroller, you've summed up your situation very well for us, so I've merged your posts into this thread covering ATSC-equipped DVRs and PVRs so please read through it for reviews and other tips.
You should also check out this one too:
DTVPal (EchoStar TR-50) OTA DVR
stampeder is offline
Old 2009-08-28, 09:22 AM   #183
mr weather
There is a Panasonic DMR-EZ28 which is the newer model to mine and is apparently carried by 2001 Audio Video in the GTA. For the record, my EZ27 has component and HDMI output but as I indicated in an earlier post it downconverts everything to SD before passing it on to the tv.
There are ATSC set top boxes that offer component and/or HDMI outputs that will allow you to watch real OTA HD on your HD-ready tv. Boxes by Samsung and Zenith come to mind.
The vast majority of boxes, however, only output an SD or worse (analog via RF coax). You'll really have to do your homework to ensure you get what you want.
mr weather is offline
Old 2009-08-28, 12:54 PM   #184
stampeder
Yep, the HD-output ATSC boxes are in this thread, but they aren't DVRs/PVRs:
ATSC High Definition Tuner Boxes (Non-Recording)
and the most highly regarded of those is currently the Winegard.
Old 2009-08-28, 06:51 PM   #185
classicsat
Just to make sure you have your expectations correct, the "converter" boxes built for the Coupon program in the US are basic DTV tuers with SD only analog video/RF out.
The FCC didn't provided the boxes, nor even the coupons; an Act of Congress suppied the coupons.
classicsat is offline
Old 2009-08-30, 05:49 PM   #186
Ott8915
In regards to OTA ATSC PVRs, I recommend you look into FTA Receivers that have built in OTA (ATSC) tuners. I use mine to record NASA TV (FTA) and OTA channels on to an external hard drive in full HD.
There is a separate thread regarding this although it is out of date:
http://www.digitalhome.ca/forum/showthread.php?t=34990
Ott8915 is offline
Old 2009-08-30, 07:00 PM   #187
stampeder
Instead of that old thread, OTA HD PVRs based on FTA are discussed in this thread:
ATSC Tuners in Satellite or Cable Receivers
Old 2009-09-16, 11:08 PM   #188
jraheb
ok, this is getting very frustrating. I've been searching for a good unit that will play/record DVD, HDD and have a ATSC/NTSC tuner. My search through here can give me great units that do either DVD or HDD, but not both.
Does anyone have a recommendation for a unit out there that can do the above?
Thanks!
jraheb is offline
Old 2009-09-16, 11:11 PM   #189
poutanen
I think the only thing that can do what you want is a HTPC (home theater PC)...
poutanen is offline
Old 2009-09-16, 11:15 PM   #190
jraheb
Have there been any thoughts or experiences with the Sony RDRHX780?
jraheb is offline
Old 2009-09-17, 10:32 AM   #191
roger1818
Phillips used to make one, but it downconverted everything to SD.
Other than an HTPC, your best bet might be to buy a box that can record to a hard drive and be networked to your PC so you can burn programs to DVD there. One option for this is the TVIX R3310 PVR. You can read about it starting at post #141.
roger1818 is online now
Old 2009-12-18, 09:14 PM   #192
Nester5000
I have the 750 model and neither it nor the 780 have an ATSC tuner. Other than that it's a good machine.
Nester5000 is offline
Old 2010-01-04, 06:27 AM   #193
RZ500Guy
Default DVD recorder with digital tuner?
A freind of mine realy wants a DVD recorder with a harddrive. He also needs it to have a digital T.V. tuner. I told him I would take a look around on ebay for him. Any model sugestions? I'm not a big fan of these things but it sounds like it would work for him as he just wants to be able to record over the air T.V. shows and maybe burn them to a DVD.
RZ500
Last edited by 57; 2010-01-04 at 12:19 PM. Reason: Moved to existing thread, please read earlier posts.
RZ500Guy is offline
Old 2010-01-04, 07:20 AM   #194
blueroomelectro
An HTPC with SageTV or Windows7 could do that. OTA is usually recorded raw and is several gigabytes per hour.
Bill
My blog
blueroomelectro is online now
Old 2010-01-04, 12:11 PM   #195
RZ500Guy
Thanks for the reply blue. The guy I'm trying to help out is older and doesn't even own a PC. Even if I was to try and set something up for him I don't think he would be able or willing to use it. It really needs to be a stand alone unit.
RZ500
RZ500Guy is offline
Tags
ota hdtv
OTA Forum Sponsor
