I was wondering if anyone with a built in OTA tuner is able to record HD broadcasts using a regular dvd recorder? Or do I need to buy something with a Hard drive?
I imagine the TV will have to be turned on and tuned into the channel I want to record as well since the tuner is built in? I work swing shifts and might have to quit my job now that I am missing all these wonderful high-def broadcasts! Somebody help me! Last edited by stampeder; 2007-01-17 at 03:54 PM. Reason: New thread from old posts - see post #3 for introduction |
#2 | |
There are several issues here. First of all most TVs don't have any type of video output connecter. Secondly, unless you have and HD-DVD or Blueray DVD recorder you cannot record in HD (it is theoretically possible to record HD programs on a standard DVD, but I only know of one DVD player that will play this type of DVD and you will probably get less than an hour of programming per disk). Apparently come February all video recorders (DVD, VHS or HDD) sold in the US will be required to have an ATSC tuner, but I don't know of any DVD recorders on the market yet that have one (there are a couple HD HDD recorders and an HD VCR that have them). Even if they do magically appear on the market, I am sure many (all?) will down convert the signal to SD Is there a thread for talking about set top OTA HD recorders? |
#3 | |
This thread is for discussing STBs (Set Top Boxes) that can record Digital OTA programming via ATSC. At present (January 2007) these are the options:
Last edited by stampeder; 2007-01-23 at 11:52 AM. Reason: Added Tivo 3 to list on 99gecko's info |
I am currently recording OTA broadcasts using a Silicon Dust HD HomeRun device, and my Linux based MythTV PVR system. Works fantastic!
Tom |
Thanks for the info, rpr
I've changed the topic of this thread so that we don't cover the same things covered in HTPC threads here at DHC. |
#6 | |
Did anyone see anything in the CES coverage about these video recorders? On the Toshiba press release I found the following:
So at least one vendor is planing on releasing DVD recorders with ATSC tuners soon. Last edited by WoodButcher; 2007-01-22 at 11:37 AM. |
I found press releases for 3 more DVD Recorders with ATSC tuners. One from RCA (who have also announced an ATSC tuner for old analog TVs) and two from Samsung. They are all going to be in the $250-$320 US range and will be available in the middle of 2007.
Edit: I also found Panasonic's press release. It looks like all of their DVD recorders in 2007 will have digital tuners (other brands entry level machines seem to lack any tuner). I should also note that all of these DVD recorders seem to record in either EDTV or SDTV but not HDTV. Last edited by roger1818; 2007-01-22 at 08:55 PM. |
Will they pass through HD from the tuner to the TV?
Many of them are capable of "up-converting" to HD resolutions from DVD. The tuner will not be to useful if it doesn't support HD, or down-converts the output. |
#9 |
Probably the only OTA PVR option available right at this moment without any strings attached is to use a PC with any of the ATSC cards or new USB tuners on the market.
#10 |
Now that I think about it, there is one other option that I remember, but it is of no value to electrocutioner or WoodButcher as it is not an STB. Therefore it is of no value to anyone with an existing STB - only those who are considering a purchase of a HDTV and would like to go OTA that is.
LG had 50" & 60" plasmas with ATSC tuner and integrated 160 GB hard drive DVR - 50/60py2dr & 50pc1dr are the model #'s. I don't remember anything about their actual quality/capabilities though - either the plasma HDTV or the integrated DVR. The first two are older models now and they were very expensive when they first came out in the US. At the time they were high-end models. The 50pc1dr was considered a lower model. If I recall they weren't immediately available in Canada and I don't recall ever seeing them in a retail store here. Just posting this here since it deals with OTA PVR options. |
#11 |
Sony used to make four HD PVRs with built in ATSC tuners (the DHG-HDD100, 200, 250 and 500). These were very expensive and thus not very popular. You can still find them on e-bay now and again.
#12 |
Likewise with finding one of these LG ATSC DVR units somewhere:
http://reviews.cnet.com/LG_LST_3410A...-30958320.html |
#13 |
Sorry, I should have posted this when this thread started.
Another review of yet-to-be-released equipment: C|Net review of DVD recorders with built in ATSC tuners from CES 2007 I'm really curious how the offensive language "TV Guardian" works. |
#14 |
Here is another link which describes what the different manufacturers are doing with the FCC's mandate for ATSC tuners in devices that that receive television signals: Tuner Rule Hits Recorders.
All of Panasonic's recorders will have both digital and analog tuners. LG, Toshiba and JVC will have recorders with and without tuners. Zenith (a subsidiary of LG) will only have tunerless recorders. LiteOn will get out of the branded DVD recorder business. For those who want a VCR with an ATSC tuner, it looks like the only standalone VCR will be the expensive JVC HM-DT100 Digital VHS HDTV Recorder (though I don't think it is available in Canada). Other than that, the only way to get a VCR will be in a DVD/VCR combo unit. |
#15 | ||
| Tags |
| ota hdtv |
