Close to making the plunge on a ViewSonic N4200w - Canadian TV, Computing and Home Theatre Forums
Old 2007-01-11, 11:11 PM   #1
roguechameleon
Default Close to making the plunge on a ViewSonic N4200w
I'm pretty close to buying a ViewSonic N4200w from COSTCO:
http://www.costco.ca/en-CA/Browse/Pr...topnav=&browse
Price is $1,799.99 and being from COSTCO, there is no element of buyer's remorse.
That being said... I could use a nudge towards biting the bullet, or a corrective slap in the face telling me to look elsewhere.
Anyone? Guidance? Help?
Rogue Chameleon
burn leafs burn!
roguechameleon is offline
Old 2007-01-12, 07:40 PM   #2
roguechameleon
No opinions on this tv?
Rogue Chameleon
burn leafs burn!
Old 2007-01-14, 02:33 PM   #3
Roadhouse
I got the Viewsonic 37" a couple of weeks ago. At first I was a bit put out by the SD PQ, however with the help of this forum and those participating, I've tweaked the settings to the point where we are quite happy with it. The guys at Costco told me the only 37"'s they got returned was a couple with audio issues.
I don't have any complaints as of yet and will most likely keep it. I'd say if you like what you see so far....get it and set it up. Once you get it in your place, you'll really see whether or not you like it.
Good Luck
RH
Roadhouse is offline
Old 2007-01-14, 04:48 PM   #4
roguechameleon
Thanks RH... appreciate you taking the time to respond.
I assume that the 4200 has the same tweaking features as the 3760?
Rogue Chameleon
burn leafs burn!
