Difference between Viewsonic N3751 and N3760 - Canadian TV, Computing and Home Theatre Forums
Old 2007-01-06, 10:28 PM   #1
drayog
Default Difference between Viewsonic N3751 and N3760
There is a price difference, what is the difference in the two TV's ? Is the 3760 worth the extra $$$. How about the 4060 ? Better than the 3760 and is it worth the extra 4500 ? Thanks
drayog is offline
Old 2007-01-06, 11:29 PM   #2
elapsed
The N3751W is newer than the N3760W. It features more HDMI inputs, less power consumption, PIP, and better audio than the 60w. Between the two, I would lean towards the N3751W.
The N4060W is larger, so its up to you if this is worth the money. What is your viewing distance?
elapsed is offline
Old 2007-01-10, 08:38 PM   #3
roguechameleon
The 3751 is newer and cheaper than the 3760?
I find this perplexing.
Rogue Chameleon
burn leafs burn!
roguechameleon is offline
Old 2007-01-10, 08:45 PM   #4
Roadhouse
Both the same price at Costco. Differences as noted above.
Roadhouse is offline
Old 2007-01-10, 08:50 PM   #5
roguechameleon
Hmmm.. whaddya know?
http://www.viewsonic.com/pdf/us_eng/...hart_lcdtv.pdf
Rogue Chameleon
burn leafs burn!
