Hi Guys, I would like to buy a new Receiver from my home theater. Here is what I already have:
2xPradigm Titan 2xParadigm Atom 1xPAradigm C170 1xParadigm PDR10 I am thinking about the new Pioneer VSX1016Tx. I really like the HDMI switching feature but I'm open to anything else. My budget is between 500-800$ TKX |
For a similar setup I have a Sherwood Newcastle 771 on order. No HDMI, but it does have lip sync which was a major factor for me. I'll let you know how it sounds with the Titan's in a few weeks when it's all set up. In theory the amplification sound quality should be the main advantage of the Sherwood.
There is a real good review of the Yamaha RXV659 at Audioholics.
http://www.audioholics.com/productre...aRX-V659p1.php It should fall into your price range. |
I'd say go with the 1016tx. Most bang for your buck, features and functions you'll never use, but fun to play with.
I wish i had waited, got my 1015 for myself last christmas. I'll need to upgrade someday, but that'll give me an excuse to put the 1015 in the bedroom.
Where can I find a Sherwood retailler ?
It's good to hear that you share my optimism. Honestly because the whole package was fairly inexpensive, we didn't do as thorough auditioning as we could have (I was helping a friend buy). Yeah, it's a little shy on features, but has the most important ones that we were looking for (lip sync, 3 component in, component upconversion, parametric room optimisation). It's just a good fit for my friend's purposes. No HDMI but unless a receiver has full 1.1 capabilities it's of no use anyways IMO - just a switch isn't that useful on its own.
InTandem is the Canadian distributor. If you email them, they'll send you retailer names
http://www.intandemcanada.com/itoolk...oducts&grp=101
I'm not washed up yet |
#9 |
Hello all,
I need some help picking a decent receiver. The things that I wanted from it are multi-room/zone, HDMI 1080p compatible and 1080p video upconvert. I don't want (or able) to spend a fortune on this. I liked the looks/specs from the new Sony STRDA5200ES. Or what about the Yamaha HTR-6090 Yamaha HTR-6090 It will be working with a Sony KDL46XBR2 and I still have to get surround speakers but i'm thinking of getting Mirage Nanosats for their size (if you have any thoughts on that as well please jump on it). Any recommendations/suggestions? Thanks in advance and HAPPY NEW YEAR! Last edited by hugh; 2007-01-03 at 01:30 PM. Reason: removed retail link |
#10 |
Welcome to DHC! Between the two receivers you have selected, I would lean towards the Yamaha. But keep in mind that neither model is capable of scaling all inputs to 1080p, they are only capable of repeating 1080p over HDMI and converting all inputs to HDMI.
Another model you may want to audition is the Denon AVR-2807. Enjoy! |
#11 |
I've been looking for a new avr myself, and here's what i've gathered so far...
Actually the STR-DA5200es is being marketed for its full hd 1080p upscaling ability with its new 10bit Genesis FLI8668 chip. It can upscale all analog inputs to 1080p over hdmi. Now how good is this scaling is questionable... The htr-6090 i believe is similar to the rxv2600 line, which is a nice receiver with good reviews. I dunno if the 6090 will be able to pass a full 1080p signal thru hdmi. You may want to check on that. But if its like the 2600, then it can upscale analog inputs to as high as 1080i. The Denon 2807 is also a great reviewed receiver. It's Denon quality and will pass a 1080p signal thru hdmi. But its got no upscaling ability other then de-interlacing ability -480i to 480p. Another avr to check out is the Pioneer elite tsx-84 or 82. They have similar features to the yamaha 2600. the 84 model has 4hdmi in. hope that helps, and good luck. |
#12 | ||
HDMI Up Conversion (Input sources up to 1080i) Composite, s-video and component video sources can be converted to HDMI output, minimizing the number of connections needed from the receiver to the television display. http://www.sonystyle.ca/commerce/ser...ductId=1002535 Quote:
#13 |
Hmm I might be wrong, Sony contradicts itself on the specs page:
Up Conversion: Yes (HDMI Up Conversion from Component, S-Video and Composite to 1080p) http://www.sonystyle.ca/commerce/ser...ductId=1002535 |
#14 |
For a demo of the str-da5200es check out
http://www.sonystyle.com/intershopro...s/STRDA5200ES/ It's got a demo of the gui and 1080p upconversion, its the only receiver on the market currently that does this in the price range. Looks like the htr-6090 is similar to the updated v2700/1700 line, so accepts the 1080p |
#15 |
I'm also in the market for a receiver.
Have you given any thought into the Pioneer Elite VSX-84TXSI http://www.pioneerelectronics.com/pn...985784,00.html I looking at something that will still be good come 3 yrs down the road! |
