#61 |
is the DCT700 available? in saanich,victoria.bc thanks
#62 |
Location: BC. Shaw Cable, 42" Samsung DLP, 6416 w/expander & DCX3400
Best to call into the local office and they can check your account and area to see if the product is available yet.
Designated Shaw Employee representative for Cable & Digital Cable for Digital Home Forums. |
#63 |
The DCT 700 has been available in Victoria for the last month. I picked one up last weekend.
#64 |
Location: Victoria, BC, Shaw HD Plus Pak, DCT 3416, PS3 Slim
Very informative forum... thx all!
Has anyone had success getting off the hook from the $1.99 per month per additional terminal charge that Shaw asks for? I currently have 2 TVs, plus a PC with a Sabre dual tuner card on Windows Media Center. I currently have an all analog setup. So, for $55 each (Victoria, BC), I could pick up 4 of these, but shaw will end up charging me $6/mo just for the pleasure of buying and using their DCTs? Seems a bit over the top to me... certainly a barrier to moving into the digital world My other question RE: DCT700; I understand that these have composite outputs in addition the standard coax output. My dual TV tuner card has 2 coax inputs, plus 2 s-video and 2 pairs of composite audio inputs... an inconvenient mismatch for the video transfer. Is there even such thing as a composite video to S-Video cable conversion available? Thx! Last edited by Greg At Home; 2007-10-30 at 01:45 PM. Reason: typo |
#65 |
#66 | |
My tuner card (Saber 2020) comes with 2 adapters to convert female RCA to RF type male adapter (as seen in the 2nd diagram here). According to the manual documentation, these are "NTSC to PAL antenna adaptors", which doesn't really apply to me in this case. Unfortunately, there was nothing for composite to S-video, and nothing of this description was outlined in the package contents. I suppose I could just use the RF connections directly, but of course that will sacrifice the quality somewhat. |
#67 |
Sorry Greg, I was looking at the Saber DA-1N1-E Combo Analog/Digital TV Tuner Card that has it included.
You can try part no. 1511239 at the thesourcecc.ca or in store. It seems a little pricey, but at least there's one "source" (ha ha). |
#68 |
And to answer the other question about getting around the $1.99/month fee for each DCT. Unfortunately that is not likely to happen. I have seen it happen only a handful of times and it is almost always due to human error in putting the order through. Once someone else finds it they are supposed to correct it. Sorry.
#69 |
Does the $49 DCT 700 include the free PPV movies and the monthly credits?
#70 |
Shaw hasn't done free PPV credits in a couple years and the monthly credits have been replaced with a 1 month free preview for new customers.
#71 |
that's too bad...if it was still in effect YOU would be losing money ($15 in PPV's, $100 in credits)
#72 |
I have a choice of 2500 or 700 for roughly the same price. I am aware of most of the differences (eg. outputs) between them...
Does anyone know whether the DCT700 picture is better than the 2500 for basic cable? I live in Vancouver and, as I understand it, basic cable is analog, so tuned as such by the 2500 but converted to digital by the 700. Regards |
#73 |
Shaw Geru (or anybody that knows Shaw well), will Shaw deliver the DCT700 to your door for a small fee, instead of it being delivered to your home and added to your bill?
Dynex 32 inch LCD / Panasonic 1000-watt HT / Apple TV 160GB / Motorola SD digital box / PS3 500GB / Eee Box B202 500GB |
#74 | |
#75 | |
For example CBS send a digital signal to Shaw. They pass that on to the DCT 700 and it puts a digital quality signal on your TV. They also convert the digital signal to analogue to put out to all those customers in the cable plant who have an older DCT or no DCT at all. Plus the DCT 700 is about 1/10th the size. If you are looking for S-Video and optical spdif out then go with the 2500 though.
| Tags |
| shaw |
