#166 |
http://www.digitalhome.ca/forum/showthread.php?t=76077 Recorder & STB
http://www.digitalhome.ca/forum/showthread.php?t=57741 Useful post - FAQs, Search Tips, Optimization, etc.
#167 |
How is the closed captioning turned off and on with the DCT700? Thanks.
#168 |
Location: BC. Shaw Cable, 42" Samsung DLP, 6416 w/expander & DCX3400
These DCTs do not offer closed caption. Only the advanced set top boxes have this feature. To use CC on a DCT 700 you must do so using the TV.
Designated Shaw Employee representative for Cable & Digital Cable for Digital Home Forums. |
#169 |
I recently picked up a 47inch LG tv, and have had nothing but problems with my DCT700 since I hooked it up... I removed the coax cable from my old tv, and connected it to the new tv, it was working great... When I went back to use it later in the evenining, the DCT700 was unresponsive to the remote... I disconnected the coax cable from both the tv, and the DCT700, and reattached them using a yellow RCA cable, as well as resetting the unit by unplugging it... After rebooting it, it was responding to my requests by the remote... The following morning, after powering the tv off, once again the DCT700 was unresponsive to the remote... I disconnected the yellow RCA from the DCT700, and the remote would operate using ch + and -, but upon reconnection of the RCA, it would again not respond... This morning, it was still not working, so I disconnected the RCA cable from input 1 on the tv, and connected it to input 2 on the tv, as well as resetting the DCT700... Once again, the unit functioned properly... I returned home from work to find it not working again...
Anybody have any ideas? |
#170 |
Premium Supporter
Sounds like it's a bad box. Call Shaw or go to one of their offices and they will swap it out for you.
If you want more then ask for it rather than going hungry. If you want more than I have then you should ask. They're going to park their car over there. |
| Tags |
| shaw |
