Yamaha RX-V559 Receiver with passive sub? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > A/V Receivers and Amplifiers
Old 2006-12-31, 10:37 PM   #1
BigOil
Default Yamaha RX-V559 Receiver with passive sub?
I recently purchased the Yamaha RX-V559 Receiver to act as the hub of all my equipment and realized that I couldn't hook up my passive subwoofer because there is only a speaker jack for an active sub. (no slot for a two wire sub woofer speaker input)
Is there any way I can avoid going out and buying a new active sub/use my existing kit?
BigOil is offline
Old 2007-01-01, 08:56 AM   #2
987654321
Yes - use a mono or stereo basic amp hooked up to the sub out RCA connectors.
There are good sites that offer used units.
987654321 is offline
Old 2007-01-01, 02:27 PM   #3
BigOil
thanks. I did some searches for a basic amp and everything that comes up seems overkill for my simple application. Do you have an example of what you meant?
BigOil is offline
Old 2007-01-01, 04:15 PM   #4
mrhooie
well, if your sub has a crossover )probably not though) you can hook it up through the B speakers and that will get you bass. however, not LFE as it is intended
mrhooie is offline
