2006-12-31, 05:18 PM
#1
Infraction for Kevin270: Trolling
Post: July 18th: DSR530 Code CC Fixes, Features & Bugs
User: Kevin270
Infraction: Trolling
Administrative Note:Message to User:
Kevin, I'm going to ask that you not post in the Star Choice forum anymore. You simply have nothing but venom for Star Choice and you're not contributing anything positive. You are simply trolling.
The result is a number of members have reported your posts.
You're welcome to post in other forums but if you post in the Star Choice forum anymore your account will be suspended
Original Post:
Originally Posted by Yogibear
Anyways, i know the dsr530 is not a perfect machine but it is better than nothing. I did not want to wait any longer.
I have not used a VCR since 2000. I bought my first PVR back then, but it was not a high def PVR. It was one of the Rogers cable PVRs. The only problem I recall with that machine was with the timers - you could set it to record all episodes of a program (as it had record by name). Sometimes when setting it to record only the first program, it would record all programs for the same day. IE: It would record the first airing of Will & Grace, and 2 other episodes that were repeats of the first. I had dual recording, rewind worked, FF worked, jump keys worked. It was an amazing machine, but it was not high def and we just bought a high def TV in 2005. So part of the problem for us is that we switched to a machine that is severely handicapped when it comes to doing these basic things. Had the DSR530 been my very first PVR, I may not have noticed these problems. This is what I suspect is happening to most people who own the 530. They are not noticing anything is wrong because they never had a machine that worked properly in the first place. I did some research before buying the 530, but my mistake was getting feedback from the wrong people, and not doing a thorough investigation before buying. Big mistake!!
Anyhow, glad you are happy with it across the river from me in Gatineau.
You have a Happy New Year too.
