TH-42PX60U with XBOX 360 issues - Canadian TV, Computing and Home Theatre Forums
Old 2006-12-29, 09:38 AM   #1
dreamaz
Question TH-42PX60U with XBOX 360 issues
Sorry wan't sure to post a new thread on this or just work with the existing thread.
I bought the TH-42PX60U this weekend along with the xbox 360. Set the xbox for HDMI. When i started to play Gears of War, i noticed that everytime there was sound involved (gunfire, sound effects) i woul dget these red horizontal lines across the screen. It would look ok when i was just standing there but when i moved or fired i had them. Also, sound only game out of one of the speakers and a buzzing sound out of the other. So i unplgged the RCA for the buzzing speaker and got sound only out of the one, but still red lines.
Decided to unplug the xbox and put straight into my standard 27" RCA box and works perfectly, no lines, no sound buzzing. Would anyone know what could be causing this?
Thanks for the help
dreamaz is offline
Old 2006-12-29, 10:26 AM   #2
rikee
Might be a problem with your HDMI cable. I'm not a Xbox specialist but try to plug it with component cables and see the difference. Also, do you have to same problem with other equipement hooked up with HDMI ? I suspect a conflict with HDMI cable.
rikee is offline
Old 2006-12-29, 12:00 PM   #3
dreamaz
Going to check this out soon as I get home. Thanks for the reply!
dreamaz is offline
Old 2006-12-29, 07:06 PM   #4
PrimeBane
There is no 360 HDMI cable (not does MS support one) so I'm curious how you managed that in the first place.
Stick with the component cable that should have come with the 360.
I have the same tv with a 360 with no such problems. Perhaps try watching a DVD with it to see if something similar occurs. Perhaps you got a dud tv?
Consider calling the MS 360 support line as well.
PrimeBane is offline
Old 2006-12-29, 10:10 PM   #5
dreamaz
Used only the 3 component cables and looks fine now. But when i use the 5 plugs that come with the xbox HD AV cable, i have the problem...
Thanks for your help on this guys..
dreamaz is offline
Old 2007-01-03, 05:56 PM   #6
acastruc
'Used only the 3 component cables" ? I think you mean composite cables ,i.e. red/white/yellow.
Component cables are usually coded red/blue/green and are for video only.
Anyway, as to your original problem, it sounded like you accidently swapped cables on the '5 plug HD AV cable' as you call it, probably mixed the red audio cable with the red video component cable.
Last edited by 57; 2007-01-03 at 06:28 PM. Reason: Changed second composite to component
acastruc is offline
