HDMI cables - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2006
Old 2006-12-27, 12:40 AM   #1
viking1
Default HDMI cables
I've got the Phillips dvd 5960 and the sony kdf-55e200 tv. (over component)
Does it make any sense to spend $200/$300 on a hdmi cable. There are $20cables out there or even less on ebay. How do they compare to those expensive ones?
viking1 is offline
Old 2006-12-27, 12:42 AM   #2
It makes no sense to pay more than say $20 if the cable is less than 10'. See the following threads.
http://www.digitalhome.ca/forum/showthread.php?t=30452
http://www.digitalhome.ca/forum/showthread.php?t=17873
Does it make any sense to pay more for the cable than you did for the DVD player?
57 is offline
Old 2006-12-27, 12:53 AM   #3
marsilians
Default Discount Cables
You may also note that it does not make much difference for other cables such as Optical (toslink), coaxial, etc. $20 will get you pretty much the same quality as > 100 ones.
marsilians is offline
Old 2006-12-27, 01:02 AM   #4
viking1
Thx. That's what I thought. How big of an improvement can I expect with hdmi over component.
viking1 is offline
Old 2006-12-27, 01:38 AM   #5
The answer to that question is in the second link of post 2 (points 2, 3). Please take the time to read it. I took the time to post it.
57 is offline
