#571 |
As m3repair says, it can be done but my question is why not just use a 2 x 4 switch inside and just run 2 lines from the 91 LNBF. The 3100's can see nothing from 82 anyway.
This would cost around $10 for a switch. |
#572 |
Thanks for the info m3. I wasn't too sure if they'd work with a DPP lnb.
Pinza, I'd like to keep the ability for him to get the HD sets in the future without me having to go back and install another lnb and/or switch, besides I can get a DPP QUAD for $40 to $60 where I live. |
#573 |
I have a friend tbat right now is using a single LNB with a 3100. Can ge change out the LNB for a DPP Twin? I know you can't have just 1 2700 connected to DPP Twin. But can you have just 1 3100 on it. He wants to get a 9241 to replace the 3100 at a later date.
#574 |
I'd like to know if we can use a Dish 500 Twin LNB with a 9242 receiver to get 91 and 82?
#575 |
Yes I think you should get 91 and 82 with the Dish twin.
#576 |
rouge any receiver with that's campatable with dpp gear actually has a dpp symbol @ the coaxial input on the back of the receiver.
jamsat: yes.
"The quality of your question will directly effect the quality of your answer" |
#577 |
witchdoctor if you can get dpp "quads" for 40-60 dollars i'd be interested in buying 100 from you.
#578 |
#579 |
So my friend can use just one 3100 receiver on a DPP Twin. 3100 receiver is not a legacy receiver it has DP on the back.correct?
And later replace the 3100 with a 9241. |
#580 |
Ok read the following thread:
http://www.digitalhome.ca/forum/showthread.php?t=151219 And a 3100 by itself can be connected to a DPP Plus Twin |
#581 |
My 9242 went kaput yesterday after 4 years of service to me.
I guess I am now going to have to get a single reciever for each tv in the house now. My question is- Can I just buy the 2 new recievers and just plug and play after activating them from Bell? Will the existing setup with all the cabling and the dual LNB on the roof be the same? |
#582 |
The existing cabling should work, once a new RG6 is run/connected to the receiver at the second TV. Legacy equipment will be fine as is. Just be aware that DPP splitters only work with dual tuner receivers so a second line is necessary with DPP equipment.
Are you aware that Bell will provide a refurbished 9242 receiver for $150? That's a cheaper option if available.
#583 |
Is LNB 82 the electronically the same as LNB 91 ? When I bought LNB 82 the guy just grabbed one out of the box and said this will work. More questions to come after I get an answere.
Thanks |
#584 |
Yes they are the same.You will get 82 or 91 depending where you place it on the y yoke.
#585 |
hi all
i am running my bell system through window cracks stuffed with towels. i have a dish 500 and two 6131 recievers. the knb is as large single unit not two individuals, it says dpp when i try to connect one feed to the central junction box in my garage i cannot get a signal to any receiver in any room. obviously my wife is not impressed, i am very rural so there is no installers. as it is averything works but i would love to know which swicth or splitter i should get , then ie one or two feeds from dish to splitter or switch then connect to coax in junction box and CLOSE WINDOWS! YAY thanks B |
| Tags |
| dish, dpp, dual tuner, expressvu, hdpvr, satellite, satellite piracy |
