All Show timer not working with A&EHD? - Canadian TV, Computing and Home Theatre Forums
Old 2006-12-06, 07:34 AM   #1
ltldevl
Unhappy All Show timer not working with A&EHD?
Anyone encountering issues with PVR recording timers which are marked for every show eg: All Dog the Bounty Hunter shows on A&EHD? Not refering to VuPass.
Last night I noticed that none of the shows on this channel were marked for recording with the timers I had set. I didn't check to see if any other timers with this trait had the same issue because it seemed that they were all working and the timers picked up all the shows they should have. I did notice numerous timers in my list which were correctly marked for recording in the guide. I tried rebooting with no change. I tried deleting the timer and recreating, and still no recordings were being marked. Could this be an issue with V145 in the 9200? I don't have a second PVR to test, anyone else seeing this? Have not called Bell. I'm trying to avoid a reformat because I have a load of timers.
BEV 9242, 6131s | Samsung HL67A750 | Pioneer VSX-919AH-K | Cerwin Vega VE-15s, VE-5C, VE-5M
ltldevl is offline
Old 2009-06-11, 08:18 PM   #2
bubbles
Smile Forget VUpass
Just manually set them to record
bubbles is offline
Old 2009-06-12, 04:55 AM   #3
dosborne
Pretty much anything over than "daily" or "weekly" is a known problem. The various receiver and firmware threads are filled with "all" and "new" timer posts.
dosborne is offline
