Connecting Wii to 2Wire Router??? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Entertainment > Video Game Consoles and PC Gaming
Old 2006-11-20, 08:54 PM   #1
walker18
Default Connecting Wii to 2Wire Router???
Has anyone had success connecting the Wii to a 2Wire Router using a wireless connection? The Wii is detecting the router and I have manually configured it but when I try to connect it fails.
Any suggestions?
walker18 is offline
Old 2006-11-25, 09:08 AM   #2
walker18
Well, after a week of trying various things I finally got the Wii to talk to my router. I switched from b to b/g mode. I changed my channel to 1. I reduced my transmission rate to the minimum. I checked my MAC filtering. I tried a static IP address. Nothing worked. Then I changed my security setting from WEP - Shared to WPA and BINGO!! Everything seems to be working fine now. Hope this helps someone else in the future.
walker18 is offline
Old 2006-11-25, 10:09 AM   #3
Battscrew
Location: Calgary, just west of the center of the Universe
found that out this week for our Nintendo ds - set wep to shared and auto ip and dns
sorry just read your post
Am I getting new Sony?
Battscrew is offline
Old 2009-06-11, 11:59 AM   #4
criv555
okay so i was having the same problem, but i still am. when change my security settings from WEP to WPA it still doesnt work. It there a certain WPA? and what password am i supposed to use?
criv555 is offline
Old 2009-06-11, 12:12 PM   #5
dezzpayne
While this advice obviously does not help at this point whenever I have a wireless problem the first thing I do is connect without security and go from there.
dezzpayne is offline
Old 2009-06-11, 12:53 PM   #6
Jake
I had difficulty getting my Wii connected as well. I tried many of the same things as you channel, b/g mode etc but in the end the one thing that fixed it was the length of my WPA PSK passcode. It was 63 characters long. I shortened it to 8 and it worked. I put all the other router settings back.
Recently though I notice the "glowing slot" for many hours at a time. I have not looked into it but I turned off the connection as a precaution.
Jake is offline
Old 2009-06-16, 04:14 PM   #7
Erock
That Bold part is pretty key... doesn't matter what encryption if you don't have that right
The password should be set by default to WEP-open & you'll find it on the side of the unit in square brackets (10 digit number), right next to some bar-codes
Erock is offline
Old 2009-06-17, 01:15 PM   #8
criv555
"open & you'll find it on the side of the unit in square brackets (10 digit number), right next to some bar-codes"
open the wii? or like my router?
criv555 is offline
Old 2009-06-17, 01:25 PM   #9
Erock
lol, no don't open anything!
I mean "WEP-Open" as the encryption type.
Just look on the side of the 2wire.
Erock is offline
