My 6412 does not know it is a PVR anymore! - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable HD tuner and HD PVR Discussion
Old 2006-11-19, 09:05 PM   #1
dabell
Default My 6412 does not know it is a PVR anymore!
My PVR thinks it isn't.
No PVR menus, no listings button of recorded shows. All I have in the menus is an option to set VCR timers.
Anyone seeing the same?
dabell is online now
Old 2006-11-19, 09:47 PM   #2
dabell
Well, called in and they did a master reset from Shawland. Now I have nothing, not even channels. Nice. No recording, digital channles or HD until a Wednesday service call now.
Old 2006-11-20, 06:17 PM   #3
loracweb
Default overheating
"FYI - after many hours of tech support w/ Shaw, the unit is now working,
complete with the PVR menu options.
The issue was overheating. Please note that if a paper icon with a
dog-eared upper right hand corner appears in place of the PVR menu
option, then the terminal is in overheat mode. I thought you'd
appreciate knowing this, in case it comes up with your other customers."
One of my customers shared this information with me.
loracweb is offline
Old 2006-11-20, 06:36 PM   #4
dabell
Definately not overheating on mine. I have checked the temperature on the unit several times, has never been an issue. It could be a hard drive failure, would make some sense on losing the PVR functions.
Old 2006-11-20, 06:40 PM   #5
loracweb
well, if you turn the unit off and then press the 'menu' (i think that's the one) on the dct itself within a couple seconds you can bring up various menus.
One of those has an ide status, so you can see if the drive is still recognized.
loracweb is offline
Old 2006-11-20, 06:58 PM   #6
dabell
Just checked, drive shows ok, shows space remaining. Under general status - Error: EP00 - found the error on wikipedia -
Ep 00 Fan Failed EP00 Will only be shown on D01 of the status page (hold ok while box is off). Box will display 0 on leftmost LCD numeral (.0 ) Replace fan or Box
Old 2006-11-20, 07:02 PM   #7
loracweb
that seems to go with the overheating issue...
is your box a dvi or hdmi model?
loracweb is offline
Old 2006-11-20, 07:11 PM   #8
dabell
HDMI. I could see fan failure followed by overheating. Odd part was how only the PVR functions were lost originally, everything else was fine. Then the reset - all gone.
Old 2006-11-20, 09:40 PM   #9
Alan Bealby
Awhile back, I was watching TV and experienced a 5 minute or so power failure. When the power came back my Shaw cable box 6412 did not work properly. I had lost the program guide and PVR functionality. Basically anything accessed through the menu. I could continue to watch TV through the cable box but I was limited to changing channels through entering the channel number or using the channel up and down commands.
I called Shaw and they scheduled a service call and the cable box was replaced.
Alan Bealby is offline
Old 2006-11-20, 10:10 PM   #10
Neumania
Same thing happened to me -- came back after a day out of town and discovered my guide had no information. Called them up and they reset the box in that way they do. When I checked on it in the morning, I had guide information, but no PVR menu options -- nor did I have the high-temperature alert. Called back, was told to unplug the box for 1/2 hr and plug it back in -- I could sense this tech had no idea what she was saying, and so gave me a stock response.) It almost seems like it had downloaded the wrong guide software.
Am currently performing a factory reset (which, according to the Wikipedia page, will not erase my recordings). Hopefully this fixes things.
Neumania is offline
Old 2006-11-20, 11:16 PM   #11
dabell
I am glad to hear someone else had the same issue. I have trouble with it just being a box issue after zero guide and a forced reset. I am trying the reset as well, will see what happens.
Old 2006-11-21, 01:21 AM   #12
dabell
Factory reset no good, about 20-25 minutes to download, back to the same. No picture/guide/nothing.
Old 2006-11-22, 01:47 AM   #13
Neumania
Forced download didn't do it for me either. Another phone call, another reset -- and this time it worked. Go figure.
I don't mind Shaw technical support, but I wish they made sure they had one person on staff at all times who knows these units really well -- the level of knowledge is very hit and miss.
Neumania is offline
Old 2006-11-22, 05:25 PM   #14
dabell
Well box replaced, still nothing. Then he changed the amplifier they had installed, all good now. Apparently it was one way not two way - not too sure how this all relates... BUT.... the new box is a 6416, so I am fine in the end going 3 days with no PVR.
Old 2006-11-22, 05:46 PM   #15
They had installed a one-way amp? Very strange. Sounds more like it might have failed, becoming one-way and required replacing.
57 is offline
Forum Sponsor
