Elran Vuelta 4008 vs Berkline 088 / 45004 (in Calgary) - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > Home Theatre Construction
Old 2006-11-09, 08:35 PM   #1
Felgar
Default Elran Vuelta 4008 vs Berkline 088 / 45004 (in Calgary)
I posted over at AVS too but hopefully more Calgarians will see my question here.
In Calgary I haven't found a place to actually try out the Berkline 088's or their Adagio 45004 series. I can order them in but they'd be sight unseen and more importantly unfelt. My best local option are the Elran Vuelta 4008 but the main issue is that I'd prefer a 3-seat arch configuration and due to space restrictions, if I get the Vuelta's I'd have to go with 3 straight across.
The 088's and 45004's are ok on width with the arc config so I'm wondering if anyone has experience on how the 3 seats compare in comfort (firmness, reclining position, head rest, etc). If I had a direct comparison to how the Berklines felt vs the Vuelta it would really help me decide which way to go. I'll be getting microfibre btw, and not leather.
Thanks in advance everyone.
(If there are any Calgarians with the 088's or Adagio 45004 I'd be so gratefull if I could drop by and check them out. Maybe we could work something out to compensate for the wasted time.)
Felgar is offline
Old 2007-03-07, 03:29 PM   #2
mmanzz
Default HT Seating in Calgary
Hello read your email, I am also looking around for HT seating, did you succeed in finding what you were looking for?
Ron
mmanzz is offline
Old 2007-10-11, 12:13 PM   #3
hingkit
i'm thinking of ordering 088s .... what seats did you end up getting??
Thanks!
.wt
hingkit is offline
