Hi,
My location is Pickering, Ontario (near the boarder of Scarborough). The house that I bought has already an antenna on top of it's roof on a long pole. I am 96% sure that this antenna is from Look Communications company that was offereing digital TV service couple of years ago. Here is a link to the picture of the antenna simillar to what I have. http://www.look.ca/en/tv/tv_installation.html My question is this: Can I use that antenna for receiving free HDTV on the air if I buy a HD tuner? I already have an HD projector in my basement, but it needs HD tunner. Please let me know. Thank you. |
No Look-tv is in a much higher frequency.
CM 4248 at Buffalo,XG43 at Toronto,M4 at Buffalo,CH 11 yagi at Ham. |
Thank you for your response.
This is a California Amplifier active antenna for the frequencies between 2.3 and 3 Gigaherz.
Location: Vancouver - OTA, Pioneer KURO Elite Signature PRO-141FD, 27" iMac, WDTV Live.
You cannot use a Look antenna because they operate on different frequencies. But all is not lost, you can use the mast for attaching a recommended outdoor antenna and your existing cabling, but you can't use the Look antenna for OTA reception.
short answer is NO, but the forum won't let me reply with only 2 characters.
At what frequency range does Look transmit?
We currently transmit at 2596-2686MHz. |
#9 |
You said 'we'? but your sig says bev?
Does look do any HD?
#10 |
Could an OTA antenna such as the CM4221(8) be used on the same mast(assuming Look service is also maintained) without interference between signals?
#11 |
The different frequency ranges should ensure no cross-interference, but I would make sure that the 2 antennas are at least 30cm apart on the mast so that the reflectors of each don't cause multipath interference with the other.
If possible the OTA antenna should be on top. If you have to move the Look antenna to do that, make sure to scribe or mark the aiming direction on its brackets and on the pole so that you can remount it elsewhere on the pole again with no fuss. I don't know your location so I'm adding that its also possible to put a rotor up top and mount the OTA antenna on it, above the Look antenna. |
#12 |
Thanks very much.
I've been sniffing around for a while now, and plan on taking the HD OTA plunge shortly. I'm in Ajax ON about 1km from the lake and will likely go 4228 aimed at Buffalo with a professional install, but thought I'd inquire about the existing antenna/mast as it is at the highest point on my house. |
#13 |
I think you'll do just fine with OTA from where you are, peanuts, and here's the thread for your area to compare with others' results:
http://www.digitalhome.ca/forum/showthread.php?t=36538 Looking forward to seeing your results there too! |
#14 |
Would this antannae work to recieve HDTV signals? I did some research and found a link to it's specifications:
http://www.vytek.com/pro_mmds_2010-130.html ![]()
#15 |
When it comes to humility, I am the greatest! |
