ViewSonic 32" LCD HDTV -- any one had one? - Canadian TV, Computing and Home Theatre Forums
Old 2006-10-10, 05:34 PM   #1
Rich28
Default ViewSonic 32" LCD HDTV -- any one had one?
Any one had one? Or this one to be specific?
ViewSonic®
N3252W
32-in. LCD HDTV
Resolution: 1366 x 768
Aspect Ratio: 16:9
$889.99
The price seemed terrific, and I have a couple friends that have ViewSonic pc monitors which they love.
Here are the features:
Aspect ratio: 16:9
Screen size: 32 in.
HDTV ready – 480i, 480p, 720p, 1080i
Brightness: 550 cd/m2
Contrast: 1000:1
Response time: 8 ms -- really wanted 8ms or below for gaming
Picture-in-picture (PIP) and picture-on-picture (POP)
AV connections:
1 x HDMI input with HDCP support
RGB (15-pin D-sub)
1 x component video input (Y, Pb, Pr)
1 x S-Video input
1 x composite video input
1 x ATSC/NTSC TV tuner
1 x L/R audio input (RCA)
1 x L/R audio output (RCA)
1 x 3.5 mm audio input
1 x 3.5 mm audio output
Viewing angles: 170 degrees (H), 170 degrees (V)
Advanced ClearPicture™ electronics for cleaner, crisper images
V-chip parental control to block out objectionable programming
Closed caption
Universal remote control
Rich28 is offline
Old 2006-10-10, 08:21 PM   #2
jonoz
Default viewsonic
hello
i have two of these sets.
very happy with picture quality however when paired with star choice box you need ( I think ) to use an av receiver to get sound with the dvi/hdmi cable.
jonoz
jonoz is offline
Old 2007-03-27, 11:34 PM   #3
smnc
Wow, The price droped fast! I only paid $740 in in early March.
Anyways, jonoz, there is a mini headphone-type jack next to the VGA port labeled "PC audio" or somthing.
That port is active in both VGA and HDMI mode, so using a Y cable you can hook up the audio from a STB directly to the TV
BTW, I also love my N3252W
smnc is offline
Old 2007-03-28, 09:23 AM   #4
DavidY
Anyone here using an Xbox 360 and it's HD-DVD add-on with this 32 (or 37) inch Viewsonic? Good, bad or indifferent? Thanks.
Dave
DavidY is offline
Old 2007-03-31, 03:34 AM   #5
smnc
I had a buddy bring over his PS3.
WOW is all I can say!
Now that was HDMI, but picture quality should be the same with component...
smnc is offline
Old 2007-04-01, 03:50 PM   #6
batdude
Have a look at the Panasonic Viera 32 inch LCD. 3000:1 contrast, 8ms response and cheap. VERY NICE tv. I have the 26 inch version and love it.
batdude is offline
Old 2007-04-02, 12:14 AM   #7
smnc
Just out of curiousity, what's the $ on the Panasonic? The N3252W is only $699 at Costco now...
I'm sure the Viera is nicer, but ouch on the $
smnc is offline
