VGA/Component Video Converters - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2002 and Prior
Old 2002-04-05, 11:43 AM   #1
Systine
Does anyone have any experiece with these? I noticed that some old HD Satellite recievers have VGA output and not component. I was thinking of getting one using a converter like this: http://www.smarthome.com/77706.html . Of course I would like to plug my computer into it too!
<font size=-1>[ This Message was edited by: Systine on 2002-04-05 11:43 ]</font>
Systine is offline
Old 2002-04-08, 12:42 PM   #2
KevinO
Systine,
I'm using the Audio Authority VGA-to-Component Video Converter (part #777060 at Smarthome). It's working well to convert the signal from VGA on my HTPC (ATI Radeon LE video card) to componant on my Toshiba 50HX70 TV. I'm running a fairly inexpensive VGA extension cable of about 20' with no noise or artifacts.
I use the PC mostly to playback DVD's at 960x540p resolution so that I can do an Anamorphic squeeze on the TV. It's also usefull to rip DVD's for later playback, if I don't get a chance to view them before the rental period is up.
I'm using a Sound Blaster Live (value edition) to get the sp/dif audio out to my Surround Sound Processor, that way I retain Dolby Digital sound.
Kevin.
KevinO is offline
Old 2002-04-09, 10:15 AM   #3
cypo
Systine,
I also used the AA0960 with success to connect my HTPC to Panasonic CT34WX50. You can have it cheaper at http://www.medicalvideosystems.com/p...promotions.htm I also heard about the Key Digital VGA-&gt;Component converter, which is said to be better quality (and more expensive) than the AA. Good luck.
cypo is offline
