Rocketfish cables at FS & BestBuy - impressions? - Canadian TV, Computing and Home Theatre Forums
Old 2006-09-24, 10:20 PM   #1
eightninesuited
Default Rocketfish cables at FS & BestBuy - impressions?
Has anyone tried these cables? Futureshop and Best Buy carries them. They look similar to Monster cables and slightly cheaper. How good are they?
eightninesuited is offline
Old 2006-09-29, 06:16 PM   #2
Maelstrom
my first impression of a rocketfish component cable is i hate how the cables aren't joined. 3 seperate wires makes for more working cleaing up the cable mess
Maelstrom is offline
Old 2006-09-29, 06:30 PM   #3
JesseJ
Location: Calgary, Shaw Digital HD Plus, 3416 & Expander
They have rocketfish memory cards there too...
SHAW 2012 HD Count: +8 (51 Total not counting SC or SNETWorld)
JesseJ is offline
Old 2006-09-29, 07:12 PM   #4
eightninesuited
But how is the construction, or video quality? The component cables have a nice braided jacket, something you see in high end Monster series - for $39.99.
Old 2006-09-29, 07:32 PM   #5
JohnnyCanuck
Good cables ... certainly as good as or better than Monster, but still overpriced. If you are looking for an HDMI, TOSLink, or Digital Coax ... basically any brand will do. If you are carrying an analogue signal, then you need good quality cables. Rocketfish seem good but overpriced ... Monster are extremely overpriced.
JohnnyCanuck is offline
Old 2006-09-29, 09:27 PM   #6
eightninesuited
Well, price really isn't too much of an issue. I have a friend who works at Best Buy (CD section) who says his cost is about $10.
$10 for a component cable is quite good. But since he doesn't know much about cables or electronics, he's unsure of the quality.
Old 2006-09-29, 09:38 PM   #7
JohnnyCanuck
They are definitely good quality for that kind of price. They are better cables than Monster and you would have to pay significantly more to do better generally.
Old 2006-09-29, 09:38 PM   #8
kold
I'm sure you could order from monoprice.com and come out ahead in price, with as good or better quality.
kold is offline
Old 2006-09-29, 10:38 PM   #9
JohnnyCanuck
Better than $10 for a component video cable? I think he's got a line on a pretty good deal.
Old 2006-09-29, 11:16 PM   #10
kold
Yeah, for a component video cable that is a good deal. Some of the other things such as Toslink cables and so forth might be more competitively priced at monoprice.
kold is offline
Old 2006-09-29, 11:34 PM   #11
tat2
Rocketfish products are manufatured for BB & FS, hense the really good deals for BB & FS empolyees (who pay cost +10%). Cable have huge markup anyway.
tat2 is offline
Old 2006-09-29, 11:53 PM   #12
eightninesuited
This is the cable in question.
Old 2006-10-02, 11:32 PM   #13
gaz
I can tell you from first hand experience that the rocketfish cables are pretty cheaply made. I've used their component cables and was not impressed as the ends popped off a couple of times. Also, they are just as ridiculously tight on your AV components as the monster cables with their "turbine connectors" Almost wrecked more than one set of inputs on my TV.
Other than those negative things they are well priced and certainly better than spending 3x the amount on monster
gaz is offline
Old 2006-11-17, 09:13 AM   #14
Mik
These are a private label cable. Probably made for them by Ultralink or sourced out of the Orient. The fancy braiding make it look high end--but the quality of the connectors, the guage of the conductor and the shielding are what counts.
Mik
Mik is offline
Old 2006-11-17, 01:29 PM   #15
Nuje
I bought a 2m Rocketfish from FS for $70; then found everydaysource.com had a 4m one for $11.99; no difference in picture quality (quel surprise!!!)
Nuje is offline
