Digital Home Canada
Go Back   Digital Forum > Digital Forum Help and Administration > Archives > 2006
Forum Favourites Help Register Calendar Search Today's Posts Mark Forums Read
Old 2006-09-15, 07:08 PM   #1
england
Default Best 32" LCD HDTV with ATSC tuner???
I have a budget of $1500, and am after a 32" LCD HDTV with ATSC tuner for over the air HD broadcasts using an outdoor antenna. Anyone seen a decent one around?
england is offline
Old 2006-09-15, 08:40 PM   #2
elapsed
Top two 32" models with ATSC tuners, in your price range are:
Sharp LC-32D40U
Samsung LNS3241D
elapsed is offline
Old 2006-09-17, 11:47 AM   #3
Kevlarstar
I would go with the JVC LT-32X887. Although the Sharp will probably generate a little less video noise the JVC will give you much better color processing and details. As for Samsung they cannot reproduce a good dark image.
Kevlarstar is offline
Old 2006-09-17, 01:38 PM   #4
026163
i have the same question, only I want to know the cheapest TV that is 32" with an ATSC tuner.
i've seen many 32" tv's for 800-900 but none of them have ATSC tuners.
026163 is offline
Old 2006-09-18, 04:06 PM   #5
jonnyfreeze
Default 3252 has one
The Viewsonic 3252w is apparently making its way on to store shelves at Costco, both in store and online. According to the specs listed on the Costco website, it has an ATSC tuner.
And the price? $889.99--the cheapest price I've seen in Canada.
jonnyfreeze is offline
Old 2006-09-18, 05:10 PM   #6
026163
^ wow great find, thats by far the best price i've seen. and it's Viewsonic, i mean it actually has a decent name. not westinhouse or digimate or some cheap futureshop TV.
edit: the picture on the costco website shows this TV:
but the CNET Reviews Page shows this TV:
which one is right? the second one looks so much better
026163 is offline
Old 2006-09-21, 10:41 AM   #7
mcpug
The first picture is the one being sold by Costco. I picked mine up last night. I exchanged the 27" version (looks like the bottom version) for the 32" version for the low price of 101.97 to cover price difference and taxes. Costco has the best satisfaction guarantee.
mcpug is offline
Old 2006-09-23, 07:43 PM   #8
england
Just bought this one below today;
The Samsung LNS3241D features 3000:1 dynamic contrast ratio, 500cd brightness, and can be used as a PC monitor or for multimedia viewing, without sacrificing picture quality. It also boasts an amazing 3.2 Billion colours reproduced using patented Samsung technology.Click Here for Special Delivery Shipping Policy More Info
WebID: 10073654
Mfr. Part Number: LNS3241DX/XAA
480i/480p 540p/960i 720p/1080i Capability 480i/480p/720p/1080i
Aspect Ratio 16:9
Built-In Protective Screen Shield No
Center Channel Input No
Channel Labeling No
Comb Filter 3D
Commercial Skip No
Component Video Inputs 1 - HDTV
Digital Focus DNIe
Display Type LCD
Dolby Digital Surround Sound No
Fine Pitch Screen Not Applicable
First Surface Mirror Not Applicable
Front A/V Inputs/Outputs 1 Side Input
Front S-Video Inputs/Outputs 1 Side Input
HDTV Compatible Yes
Headphone Jack 1
Included In Box Manual, Remote, Batteries
Invar Shadow Mask No
Language Options English, French, Spanish
Lenticular Screen No
Multi Sync Multi Source No
Parental Control Yes
Picture-In-Picture Yes
Product Dimensions 89.15(W) x 74.17(H) x 21.34(D) cm
Product Warranty 1 Year Parts & Labour
Product Weight 13.64 kg
Progressive Scanning Yes
Rear A/V Inputs/Outputs 1 Input
Rear S-Video Inputs/Outputs 1 Input
Remote Control Type Standard
RF Inputs 2
Scan Velocity Modulation No
Screen Size 32"
Sleep/Alarm Timer Yes
Sound Logic Audio Leveler Yes
Speaker Output Jacks No
Speed Channel Surf No
Surround Sound Yes
TV Guide Plus No
Upconversion Technology Yes
Variable Audio Output No
Vertical Compression No
VGA/SVGA Inputs 1
Video Input Labeling No
Watts Per Channel 2 x 10 Watts
Wide Band Video Amplifier No
More Information
FEATURES:
ATSC Tuner Built In
1366 x 768 Resolution
8ms Response Time
170 Degrees Viewing Angle
72% Colour Gamut
60Hz Progressive Scan
SRS TruSurround XT
**Requires HDTV Source
england is offline
Old 2006-09-24, 11:50 PM   #9
ponikahockey
Hey mcpug,
How do you like this Viewsonic N3253W TV? I'm looking to buy it, but can't find too many reviews for that model. I'm going to be running it as my pc monitor, and have a SA3250HD box feeding the TV signal over component.
Thanks!
ponikahockey is offline
Old 2006-10-03, 01:40 AM   #10
gaz
personally, the toshiba 32" regza (32hl66) looks pretty damn good to me. 14 bit video processing..only thing it's missing is the swivel base..
kicks the crap out of those sharp tv's any day
gaz is offline
Old 2006-10-17, 02:12 AM   #11
3mar67
I just picked up the Viewsonic 3252 from Costco. The only disappointment so far is the sound. Still haven't decided if I'm keeping it. How long will Costco allow me to keep the TV before I can no longer exchange it?
3mar67 is offline
Old 2006-10-20, 12:04 PM   #12
jsongster
Lightbulb Costco Deals...
If you have a Costco Store in reach of your home... and a membership... or friend who is a member... you can get Sony Bravia 32" with ATSC Tuner there.
I tried the less expensive Westinghouse Digital, and the Polaroid before and both had lousy ATSC tuners and other problems. Then I got the sony. $1450US and it has dropped in price since I bought one.
Check out their website. www.costco.com
Jeff
jsongster is offline
Old 2006-10-20, 01:25 PM   #13
england
ok folks, so i took the plunge, and got the samsung 32" lcd hdtv with atsc tuner, i also got the oppo upconverting dvd player, monster power bar, monster dvi-hdmi cable, monster hdmi cable 4m, sony 5.1 surround sound, and i have rogers digital cable box.
Can some PLEASE, layout the steps to hook these up to get the best picture? Everything is still sitting in the box, and I want to get the best picture I can.
thx
england is offline
Old 2006-10-20, 07:01 PM   #14
jonnyfreeze
I was just browsing through the November issue of Consumer Reports and saw that the Toshiba 32HL66 was rated near the top of the 32" sets they tested.
Old 2006-10-21, 01:31 PM   #15
caudlek
Can you comment on picture quality of both ..... your profile doesn't show how or what your connecting to it …. Cable HD? I am looking at running Rogers HD into a 26”/27” …. like to watch sports but LCD’s have “blurred” to much for me in past years (especially hockey).
Any one else have idea’s/opinions on fast motion and LCD’s …. looks pretty good on a Plasma.
caudlek is offline
Bookmarks
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
