Recommendations on a wireless router? - Canadian TV, Computing and Home Theatre Forums
Old 2006-09-05, 07:57 PM   #1
Wingman
Default Recommendations on a wireless router?
I am looking for recommendations on a good wireless router for general home use. I don't anticipate using it for any intense gaming or anything like that, but would appreciate having a speed comparable to my current plug-right-into-the-modem set up. I would also want some security features as well.
My laptop is wireless g compatible.
D-link? Linksys? Any advice would be much appreciated.
Wingman is offline
Old 2006-09-05, 08:42 PM   #2
Jake
You are going to get suggestions for just about every model. Since Wireless-n is now filling the shelves I suggest you get a wireless-g model. Many go for less than $50 and sales will have them going for less. I started with an Ethernet Linksys router and now have a no-name brand wireless router called Trendnet that I picked up for $10 including a wireless-g USB adapter. I am happy with it but one big caution. Get one that supports WPA-PSK (mine does). Some older models don't. Linksys has good support and provide firmware fixes and updates. I can't say the same about some of the no name brands.
Jake is offline
Old 2006-09-05, 11:32 PM   #3
Proteosome
The only security feature you need is WPA encryption with a suitably random and suitably long password.
With this in place, no one will be able to hack your wireless connection.
Ordinarily he was insane, but he had lucid moments when he was merely stupid.
Proteosome is offline
Old 2006-09-05, 11:40 PM   #4
elapsed
I would purchase a Linksys WRT54G or WRT54GL. I've found them as low as $40 here in Vancouver. This model is 802.11g, and supports WPA encryption. Firmware updates are excellent, and overall the series is extremely reliable.
elapsed is offline
Old 2006-09-05, 11:50 PM   #5
diogen
Another vote for WRT54G. Below $50.
And get Sveasoft or DD-WRT (3-rd party firmware) on it.
Forget about "N". It's too new, beta status and will take at least a year to make it manageable. For 3X the price.
Diogen.
diogen is offline
Old 2006-09-05, 11:58 PM   #6
cyclo
Dell has the Linksys WRT54G on sale today (not sure about tomorrow) for $49:
The Linksys is on the lower right corner
The WRT54G supports WPA, WPA2 with both PSK and AES encryption.
Given a choice however, I would suggest getting a WRT54GL... but only if you are into flashing/tweaking firmwares and stuff. You can basically flash the "GL" with an open source firmware like DD-WRT that can add more functionality to the router... such as using it as a wireless bridge.
cyclo is offline
Old 2006-09-06, 07:51 AM   #7
Iluvota
About the WRT54G..... I had a version 2 and it died. It was replaced by a version 4 which is not Linux based therefore very limited 3rd party firmware support.
I must say it is much more solid than the previous versions and a much better connection overall.
Iluvota
Iluvota is offline
Old 2006-09-06, 08:50 AM   #8
cyclo
Version 4 is actually GL, it could be flashed to use open source software. Version 5, 6, and 7 uses half the RAM and half the ROM (Flash Memory). More info here: http://en.wikipedia.org/wiki/WRT54G
cyclo is offline
Old 2006-09-06, 09:28 AM   #9
Wingman
Thanks for everyone's input! It is always nice to have a bit of background opinion when making an electronics/computer purchase.
Wingman is offline
Old 2006-09-06, 09:31 AM   #10
Jake
A lot of these suggestions are for people who like to tweak their routers and are blessed with the geek gene. For the average Joe any stock Linksys (g) will do.
Digital Home Word of the Day: bricked
Jake is offline
Old 2006-09-06, 09:54 AM   #11
otown47
I've had a DLink DI524 for a year now and it works fine.
otown47 is offline
Old 2006-09-06, 11:03 AM   #12
123sxu
Same here.
No problems. Its fast, reliable, and has been capable of doing everything I've thrown its way...I mean everything!
123sxu is offline
Old 2006-09-14, 12:16 AM   #13
MediaRoomManiac
Just picked up the DLink DIR-625 (N router) and the Laptop card for it. I must say their setup/user interface screen is very well detailed and has tonnes of features. The connectivity speeds are very good even from my main floor laptop (router/modem are on my 2nd floor). Surprisingly I am able to get signal/connectivity from my basement which I couldnt' do with my previous G routers. Quite impressed with this N technology (actually MIMO technology) that sends multiple signals out via multiple antennas and allow faster, farther data transmission to occur.
I have yet to have a dropped connection with this router (knock on wood). I got it when it was on sale at BB for $99 and I must say I'm impressed. Even though this is Pre-N or Draft N spec, I am not regretting buying into such a new technology as it is proving to be very reliable and fast.
Linksys is good also (Cisco technology), but I wasn't impressed with the signal quality and range of the WRT54G router, that's why I traded in for this one.
Had bad luck with Dlink in the past, but they have improved quite a bit.
Sony KDL46HX800, BDPS470|Pio 1020|PS3 80G|Athena AS-F1s, C1|Energy VMinis, V10|Moto VIP1232|HOne|APC UPS
MediaRoomManiac is offline
Old 2007-01-09, 11:51 AM   #14
inoutinout7
Default Best wireless router kit??
Hello, I'm running a netgear mr814 2wireless router and looking for an upgrade kit that is more reliable and not too expensive too.
This netgear mr814 keeps cutting out on me.
THkds
inoutinout7 is offline
Old 2007-01-09, 12:07 PM   #15
diogen
I'd recommend Linksys WRT54G (try to find an older version where you can mod the firmware) if wireline 1Gbps is not a must.
Diogen.
diogen is offline
