This has been requested many times. Here is the list of diagnostics shortcuts for the receivers. This is being reposted with updated shortcuts and more detailed information.
All models Accessing the memory dump screen: Press Menu, 6 (System Setup), 3 (Diagnostics). Within 5 seconds press Info, Browse, Theme. Clear NVRAM: You should be at the Memory Dump screen. Press TV/Video. A different screen will pop up telling you that you have erased the NVram. Then just press the power button on the receiver. You will lose all favorites, timers and customized settings. VCO Diagnostics (Voltage-Controlled Oscillator tests satellite tuner): You should be at the Memory Dump screen. Press Pause, 9 5100/5800/5900 models E548+ Clear NVRAM: You should be at the Memory Dump screen. Press Stop then TV/Video. A different screen will pop up telling you that you have erased the NVram. Then just hold the power button on the receiver until the red record light illuminates. You will lose all favorites, timers and customized settings. Format HDD: You should be at the Memory Dump screen. Press Play, Play, Recall You will lose all recordings! HDD Short Diagnostics (DST-1): You should be at the Memory Dump screen. Press Pause, 1 HDD Long Diagnostics (DST-2): You should be at the Memory Dump screen. Press Pause, 2 HDD Long Diagnostics (DST-2) including Transfer Rate test: You should be at the Memory Dump screen. Press Pause, 3 HDD FET Diagnostics: You should be at the Memory Dump screen. Press Pause, 6 Diagnostics + Reset LBA Failure Condition: You should be at the Memory Dump screen. Press Pause, 8 You may lose all recordings! Activate screensaver: You should be at the Memory Dump screen. Press Pause, 0 5200/9200 models Format HDD: You should be at the Memory Dump screen. Press Play, Play, Recall You will lose all recordings! HDD Short Diagnostics (DST-1): You should be at the Memory Dump screen. Press Pause, 1 HDD Long Diagnostics (DST-2): You should be at the Memory Dump screen. Press Pause, 2 If errors are found it may format the hard drive! HDD Long Diagnostics (DST-2) including Transfer Rate test: You should be at the Memory Dump screen. Press Pause, 3 If errors are found it may format the hard drive! HDD FET Diagnostics: You should be at the Memory Dump screen. Press Pause, 6 Diagnostics + Reset LBA Failure Condition: You should be at the Memory Dump screen. Press Pause, 8 You may lose all recordings! Notice from Hugh: DISCLAIMER DHC takes no responsibility for any problems you encounter performing the actions detailed above. I don't recommend doing any of these things unless you are fully aware of what you are doing. Our recommendation is to contact Bell before performing the procedures listed above. By performing these actions, you acknowledge that you take full responsibility for any problems that may occur. |
Hi,
How to get out the Memory Dump after a test on 9200 (VIP622) ? Thanks |
Press the power button on the front of the unit until it reboots.
My hard drive in the 9200 started to make a whining sound all of a sudden.
I tried a short HDD test from the memory dump screen. It said there is an error trying to read the disk and hung there. Pressing the power button in front of the unit has given me the 2 flashing red lights. Somewhere in this forum I read that the flashing red lights mean it's trying to reformat the drive, but after a few hours I don't think that's happening. I have tried hard reboots with cables off and back on, always with the same results (flashing red lights). If the machine is indeed trying to format the drive, will another drive (lots of discusion here on that) will fix the problem? Does anyone know how to get out of this flashing loop? I read somewhere in this forum that you should have your machine in dual mode when you are trying these tests (mine wasn't). |
let it go in the stream with unplugued hard drive for 24h you should pass the 2 red light then do a master reset ! with hd unlpluged again
What is the vco test?
Will any of the memory dump options discussed remove my daily schedule list? Lets just say I have reasons to not want everyone who turns on my TV to see what I have recorded and subsequently deleted.
Is there some other way to do it if this doesn't work (other than smahing it)? |
I think formatting the drive will erase the list. It also erases all the timers and recordings though.
#9 | |
#10 |
Is there any way to access the memory dump screen if when hard drive is connected machine just keeps trying to reboot IE no access to menue at all? or is there even any point in trying because hard drive may be simply toast?
#11 |
#12 |
My 9200 started to go into a reboot loop.
I tried a short HDD test from the memory dump screen. It said there is an error no nhard drive found the disk and hung there. Pressing the power button in front of the unit has given me the 2 flashing red lights. S in this forum I read that the flashing red lights mean it's trying to reformat the drive, but after a few hours I don't think that's happening. I have tried hard reboots with cables off and back on, always with the same results (flashing red lights). If the machine is indeed trying to format the drive, will another drive fix the problem? Does anyone know how to get out of this flashing loop? I read somewhere in this forum that you should have your machine in dual mode when you are trying these tests (mine was). I have tried the reset/both by power button and unplug and both with hard drive in and out but can't get rid of red flashing lights, is waiting the 24hours - streamed only way out? ( will that work?) should macine be plugged or unplugged during the 24hours if so? Anyone??? |
#13 |
It does work, but depends on the underlying problem. It is certainly worth a try.....as your options are limited.
#14 | |
#15 |
Hello again
Now I want to get this right this time so Q.? if I see red lights out 12 hours from now do I unplug and do hard reset before doing anything else or should I also wait the full 24 hours? GRRRR, well lights went out did hard reset now lights back!!! Can't win Last edited by DIG4PLAY; 2008-09-23 at 01:35 PM. |
