ATSC Converter Boxes (Non-HD, Non-Recording) - Page 45 - Canadian TV, Computing and Home Theatre Forums
Old 2009-02-04, 09:35 AM   #661
Gordono911
Default CM-7000
For D2A converter reviews check out:
http://www.hdtvantennalabs.com/converters/
Gordono911 is online now
Old 2009-02-04, 01:54 PM   #662
intravino
I have a Delhi 10y13S for WVNY with a CM 7777.
So antenna gear is not a problem, it is more my fringe location because I am almost directly North of the signal. I know that there are sending the signal more West for WVNY.
Anyways, I read on an other forum that CM 7000 box is excellent for sensitivity, I was just asking if someone had used one in a Fringe location.
Thanks,
Intravino
intravino is offline
Old 2009-02-04, 01:59 PM   #663
stampeder
Check out mille's Post #602
I found lots of posts about that box by putting 7000 into the Search This Thread tool to the upper right.
stampeder is offline
Old 2009-02-04, 02:37 PM   #664
intravino
Ok, Done that.
Thanks,
Intravino
Old 2009-02-10, 10:52 PM   #665
intravino
Default CM 7000
Hey,
I just received my Channel Master CM 7000 Digital/Analog converter box from Raybel today.
This is a primarily test, I have to lose WVNY-DT to see if this is more sensitive then the Tivo ( Microtune tuner) and my Samsung TV.
Positives:
It's a nice piece of equipment, s-video, great video output to the TV even in composite.
Negatives:
You can't manually add any channel, you have to scan or update scan.
This is just my first test but it does not look that sensitive. I plugged the CM 7000 into the 4221 that is pointed via Montreal and did not get WCAX-DT and WPTZ-DT that I normally get with my Samsung TV, But again maybe it is because of the low power of those 2 channels for the transition to DTV.
I will have an update soon on the sensitivity.
Intravino
Old 2009-02-11, 11:57 AM   #666
mille
Default cm 7000
Hi Intravino
My CM 7000 lost WCAX and WPTZ last evening, because they broadcast at only 10% of there normal power ( transition )...
mille is offline
Old 2009-02-11, 07:53 PM   #667
genx
The tivax appears to be a converter and is listed around $80. You can find converter online for about $40-$50.
genx is offline
Old 2009-02-11, 07:58 PM   #668
stampeder
genx, be sure to check whether those cheaper converter prices you have seen are actually for CECB coupon models - only U.S. residents can get those coupons legally. Canadians pay the full list price on those converters.
Old 2009-02-11, 11:35 PM   #669
happyoung
I have a Tivax box and used it a few times. It is a solid box. The price is around $90.
I also found this "CITI SMART CS 2030" on ebay around $60 from a Canadian seller, this is possibly the same box as Tivax box by the look.
happyoung is offline
Old 2009-02-12, 07:19 PM   #670
genx
Just to clarify...
I bought a new RCA converter online (ebay) for about $40US. At the time it came to$55CAD including delivery to my door. It came from US so I made sure USPS was used.*
It has analog pass through (this was important to me), small menu. The picture appears to be very good but I dont know how it compares to others. Or its sentivity. The remote works with my toshiba TV. When I bought it it was advertised as (no coupons will be accepted). Also that it was a new model.
Sorry for not posting this earlier.
*I purchase items online all the time from everywhere. I even bought my cm4228 online. USPS has proved to be dependable and no hideen fees for US orders. Some experiences with other carriers were negative.
genx is offline
Old 2009-02-13, 09:33 AM   #671
bkwa
Iam looking to find a convertor box buy it seems every one that sells them in the Hamilton area is sold out, does anyone know any place in the Burlington, or st kitts area that might sell them thanks
TV SONY 55XBR8,TV sony 40d3000, XBOX 360, HD DVD, DENON AV4308, MISSION 700 SERIES SPEAKERS, Sony bdp 360, Cogeco 6412
bkwa is offline
Old 2009-02-13, 11:03 AM   #672
intravino
Default CM 7000 Final sensitivity test
I did a final test with my setup (10Y13s into CM777) and the Channel Master CM 7000 Digital/Analog converter box.
I am disappointed with the sensitivity. I was hopping for more, if you read the comments on other forums about the CM 7000.
For WVNY-DT (1 KW for my location), I really don't get a lock with it. If you press info on the remote you see the signal meter, so I get a signal of about 10 % for WVNY-DT when it signal was overall weak. You can't watch it, a picture appears even minute or so.
The Tivo get a signal of about 30-40% with picture with pixelization but you can still watch it. Even my Samsung plasma get a signal of 20-40%.
When you do a scan with CM 7000 you get the Norwood PBS station and the St-Johnsbury PBS station listed also but no picture and barely no signal.
So the CM 7000 is downstairs on the Mitsubishi CRT TV.
Next test will be the Zenith/LG/Insignia CECB. Anyways I have two CRT TV's, so the need an other D2A box.
Intravino
Old 2009-02-13, 11:36 AM   #673
stampeder
bkwa check out this thread:
http://www.digitalhome.ca/forum/showthread.php?t=23984
Old 2009-02-13, 01:28 PM   #674
aWcMTL
Intravino
thanks for the info, intravino.
Now the choice is clear for me: probably a DTR Pal
aWcMTL is offline
Old 2009-02-13, 07:11 PM   #675
hsplrguy
Just bought one of these Artec T3A Pro this aft for a 2 year old Sony CRT 27" works great so far and $65 plus taxes I didn't find bad they are at Wintronic. Can even just hook up through antenaa input and it works on channel 3 or 4.
http://www.wintroniccomputers.com/wi...1caf7b20680008
hsplrguy is offline
Tags
dtv converter, edtv, hdtv converter
OTA Forum Sponsor
