ATSC Tuners In HDTVs (see Samsung Poll) - Page 3 - Canadian TV, Computing and Home Theatre Forums
View Poll Results: Samsung Owners: DTV tuner abnormal PSIP data quality?
Never have any problems 38 40.43%
Occasional problems with certain stations 25 26.60%
Frequent problems with certain stations 30 31.91%
Frequent problems with all stations 1 1.06%
Voters: 94. You may not vote on this poll
Old 2006-01-23, 12:16 PM   #31
stampeder
Default Latest 6th Generation ATSC Chip News
Here's a great article about the latest 6th Generation ATSC Chip news over at TVTechnology.com. They also make some very flattering mention of Canada's Communications Research Center (CRC) labs in Ottawa:
When asked why chip vendors take their technology to Canada, Citta explained that CRC is a very high-quality laboratory, funded by the Canadian government, which can test products with total objectivity.
http://www.tvtechnology.com/features...ors_chip.shtml
stampeder is offline
Old 2006-01-27, 11:38 PM   #32
john69
Default Tuners ATSC/NTSC
Hi,
I'm confused about the different support for ATSC and NTSC tuner specs.
I live in Vancouver BC Canada and we are "late adopters" in terms of broadcasting companies. Currently, afaik, only CTV is broadcasting ATSC HDTV. I have a single antenna and I need a tuner that accept both NTSC and ATSC and scale appropriately depending on the signal. For instance, the Samsung SIR-T165 mentions ATSC/NTSC as inputs, does that mean it they are separate inputs? The SIR-451 model does not mention NTSC on the samsung site:
http://www.samsung.com/Products/Digi...pecifications#
but I have heard that it does.
Bassically, I need a scaler that will tune into both NTSC and ATSC, what are my options?
Thank you very much!
john69 is offline
Old 2006-01-28, 10:42 AM   #33
jft436
Default Tuners
I read you request and I am not quite sure this is the specific answer to your question.
Most people receive their HD signal from Expresvu, Star Choice, or cable in all instances you required a special digital receiver which is supplied or bought from the provider.
Many of the new TV have a built in ATSC tuner that will receive OTA signal HD and encode them.
I do not know what OTA signals are avaialble in Vancouver BC but it would be advisable to a google search for your area OTA HD to see what stations broadcast in HD.
Many of the stations here in Toronto where on cable and sattelite with their HD signal and not providing an ota signal. This is now fixed and the major canadain providers provide OTA
Getting American channels you may be limited by signal strength/
On the back of the newer HD sets you connect the HD signal into a port that accepts HD signal only
This could be done by color component Super video or by the newer HDMI connect.The HDMI cables sell for $100.00 or more at the present time.
You need a HD tv set to receive a HD signal the newer ones are sold with build in ATSC tunes. To me this would be the better way to go than purchasing a seperate tuner.
jft436 is offline
Old 2006-01-28, 01:13 PM   #34
Sam
Hi jft,
Could you elaborate on your statements I quoted? Im interested in OTA myself. Thanks.
Sam is offline
Old 2006-01-28, 01:42 PM   #35
Maybe you should look in the OTA forums then.
57 is offline
Old 2006-01-30, 11:40 PM   #36
stampeder
The information you folks need is available in abundance here in the OTA Forum. You'll also find clarifications/corrections on the points you've discussed.
Old 2006-01-31, 07:42 PM   #37
Kevin S
I think its great, and probably THE main reason I picked the TV I did. As ironic as it may sound (having just bought an HDTV), I do not watch a lot of TV. I cancelled my cable months ago because I was paying $50/mo for nothing. I haven't missed it. Since I bought this TV, I installed an antenna on the deck and get about 20 channels OTA (including a few that are off of my disconnected cable), which is ALL the major networks. $140 inventment in antenna etc, and I now have free TV - and as mentioned, only more channels will be added over time. I very breifly considered satellite and digital cable, but I am glad I went this route and saved the $75/mo
Kevin S is offline
Old 2006-01-31, 08:28 PM   #38
Kevin S
Default Atsc, Ntsc, Qam
I have read the definitions in the FAQ, but they don't explain the differences...
What do NTSC and QAM do that ATSC does not? My Hitachi has an ATSC tuner built in, and a cable card slot (not yet available here in Canada though). Is the Cable card slot the QAM tuner? I get all my local channels through my ATSC tuner - what would NTSC do?
Kevin S is offline
Old 2006-01-31, 08:51 PM   #39
stampeder
NTSC = original analog North American OTA TV broadcasting standard, 480 interlaced visual lines, will be phased out within the next 10 years
ATSC = digital OTA TV broadcasting standard, invented in late 1990s, capable of delivering either 480 progressive, 720 progressive, or 1080 interlaced visual lines with Dolby Digital 5.1 audio
QAM = digital Cable TV broadcasting standard with capabilities similar to ATSC
Your NTSC tuner will get you all the analog stations your antenna can pull in. Your ATSC tuner will get you all the digital stations your antenna can pull in. It remains to be seen what becomes of Cable Card technology in Canada if you are a cable subscriber.
Old 2006-01-31, 09:05 PM   #40
Kevin S
Thanks for the info! I gathered that QAM was for cable, but was unsure on the difference of the other two. So NTSC is obviously what TVs have come with for the last 50 years (surprised they didn't just call it DTSC rather than ATSC). I guess I have both QAM and ATSC in my 42HDT52. If the cable card technology ever evolves here, I would be interested in using that...
Kevin S is offline
Old 2006-01-31, 09:52 PM   #41
morkys
Hey folks. What is the easiest and fastest way to HDTV OTA for me? Any suggestions for receivers? ATSC or NTSC (what?)
Also, do I need an antenna on my roof? I know every area is different, but what do you figure my options are? I am in the burbs of Ajax.
thanx
P.S. Not likely I can get it setup for Sunday Superbowl?
morkys is offline
Old 2006-01-31, 10:18 PM   #42
See also the Digital Home FAQ "Can I get Digital Cable"
57 is offline
Old 2006-01-31, 10:24 PM   #43
Kevin S
Thanks 57 - out of luck for now as you posted there, but hopefully it will catch on in the future here.
Kevin S is offline
Old 2006-01-31, 11:26 PM   #44
Kevin S
If you TV doesn't have a built in ATSC tuner you will need to buy one. Sure you can get it set up before SB - I did mine in a matter of a couple hours last weekend. I mounted it on a 20' mast off my deck since I didn't want to poke holes in the roof. Cost me about $140 total for 75' RG6 cable, UHF antenna, 2x10' masts. My TV has a built in tuner so I didn't have to buy that. With your location you may be out of luck for much OTA reception without a very good antenna. WKBW (SB carrier) may be near impossible from that range, but others can advise further. Here is a map of the local digital broadcasting stations:
http://www.remotecentral.com/hdtv/bigmap.htm
You can use indoor or attic mounted antennas, but from what I have read here it will kill half your reception.
I am sure others can give more info, but hope this helps a bit.
Kevin S is offline
Old 2006-02-01, 12:42 PM   #45
morkys
Thanx for the info. Bummer. I will look into it a little bit further.
According to the map, I am less than 25 miles (<40 KM) from the CN Tower transmitter. Perhaps it is worth a try. Its a lot of trouble to go through though.
Any advice in terms of what equipment I would need and from where? I have a projector that is HD, but no tuner, no receiver, and no antenna! (yet...lol)
P.S. I have not even checked with the costs for Rogers Digital Cable/HDTV to know the difference, so perhaps I will look into that too.
morkys is offline
OTA Forum Sponsor
