| View Poll Results: Samsung Owners: DTV tuner abnormal PSIP data quality? | |||
| Never have any problems |
38 | 40.43% |
| Occasional problems with certain stations |
25 | 26.60% |
| Frequent problems with certain stations |
30 | 31.91% |
| Frequent problems with all stations |
1 | 1.06% |
| Voters: 94. You may not vote on this poll | |||
My TV has a built in ATSC tuner and I'm wondering what the advantages (I'm sure there are a number) to owning a seperate box to handle things.
Of course I read that the LG LST-4200A was the choice of champions (in the mini-FAQ) but are there any really compelling features that make it a must for someone with a built in tuner? The features found on the site seem to be more or less what is already present on my built in tuner. Should I consider a seperate tuner (at some point)? EDIT BY STAMPEDER: older posts in this thread have been split off into their own archived thread: http://www.digitalhomecanada.com/for...ad.php?t=41504 |
Tom if your tv have a built in ATSC tuner then I would not worry about it.
Even if a STB was to give a better picture I don't think it would be a difference to notice. I will be buying a Sanyo for my office, with a built in atsc tuner and can check it against a samsung 451 and LG 4200 if anybody was curious.
CM4228/9521/7775;F.RmJvc70FH96/8300HDPvr/Dish 612;B.Rm LC52LE810UN/8642HD;Study LG50PK550/Xbox360; |
Well, that's interesting. I was almost sure there must be some innate advantage in having an external tuner.
For example, gain readings - where do they come from? I keep seeing them referenced by various people and had assumed they would be measured in the STB somehow. Though perhaps the built in tuner handles stuff like that too (haven't read the manual cover to cover yet). However, sounds like good advice if PQ remains the same. |
#4 | |
The only program was on was PBS in HDTV at 10:30am this morning.
The program that was on was hard to compare so will wait for some live sport or show on hdtv. Both receivers was feed the signal from the same two way splitter. Using component outut in 1080i the tuners was setup for. I cant really tell about the LG being more sensitive as all the channels are in strong and WB was on last night but I did not have time to hook it up, I did have time at 1am to hook up the dish 811. The dish 811 pulled in the WB49 last night. The signal strength would read max on the Samsung and on the Dish would read between 84 to 89% maybe its the scaling used. The LG read in the middle of the scale ? I will wait till there is a low signal on the Samsung to compare how sensitive the tuner is. If there is a difference the LG does seem a tiny bit sharper and maybe a tiny bit brighter in contrast. I have found a place that sells factory refurb on the web and bought another Sammy and gotone for my brother. For the price they sell the Samsung is the best value in hdtv tuner at $155.00us. Comes packaged just like you bought a new one, all the cables manual and remote etc. Comparing the Dish 811 vs the Lg the dish 811 picture is not as detailed and has slightly less contrast and brightness. But still a good picture quality, one would not be able to tell unless they were side by side to compare. Opps I had the dish rec hooked up via dvi to hdmi compared to compionent for the LG.
Well the tuner in the Lg is definately more sensitive than what comes in the Dish 811 receiver.
When the signal was low on Wham from Rochester and the dish flaked out. The Samsung also pulled in the same channels as the LG as I went to the family room and tested it. I did not test it when Wham was flaking out on dish811 though.
Yaamon,
just curious if you tried using your SIR-T451 with the indoor/outdoor HDTV antenna or you're only feeding it with the RF signal off the satellite receiver? |
Huh ??
The Samsung, LG, and Dish is hooked up using outdoor antenna's. I am using a 4228 pointed for Nbc for max signal and a 4221 pointed for Fox for max signal that also gets the Toronto stations. I combined the signal into a 7775 preamp. From the preamp it goes into a two way splitter one feeds the LG and from the LG antenna loop out the Dish 811. The other splitter feed goes directly into the samsung in the family room. I am waiting to buy a Jvc 70" 1080p or Toshiba 72" 1080p that also has a built in ATSC. I hope I answered your question. Once I get the new tv for the family room I may sell one of the Samsung or just keep it as a spare.
#9 |
Yaamon,
thx, you definitely answered my question. It's gotta be one of my slower days |
#10 |
The LG does have a more advance menu that displays more information compared to the Samsung.
You can pull up the guide for that channel that you are watching and scroll through by time and by sub channels. The remote is definately much better and can progam to control your tv, vcr, dvd and aux.
#11 |
Also, just looked on the best buy site, even though they list it as Funai, it is a Sylvania box...
#12 |
Alebowgm'
I'm more then happy with both my Samsung units. Can't really comment on this type but I've sent you a pm on another site. I guess your looking for "two" units then ? Seems like a lot more money compared to the other offer your looking at. Let us know how you make out. |
#13 |
Checkout this unit on clearout at Radio Shack.
http://www.radioshack.com/product.as...uct_id=16-3499 |
#14 |
If you are going to spend $229 you might as well spend $249.00 and to go Circuit city for the Samsung 451 a much better unit.
#15 |
The main advantages to ATSC OTA in Windsor
a) Better HD PQ than Cogeco/SC on Detroit ABC/NBC/CBS b) Access to UPN and WB HD at no charge c) access to digital subchannels d) access to Toledo HD e) The fun of summer tropo DXing. |
