#16 |
Stampeder,
Thanks for the helpful info. I have decided that the rotor itself is the problem. This evening proves again to be difficult for the unit(due to the cold evening)it does not even respond anymore. I will have to replace the driver. That being said, I need a little more advice. Now from what you've seen from my photos I have a fairly large tower. The weather is cold and snowy these days and I will not be changing it myself. Will it be even possible to find someone to replace the rotor this time of year? If so, will a ten year old combo antenna be worth it to keep, or should I change that too? The last installer said that with time the joints of the antenna eventually corrode and so does the efficiency. Is this true? The last installer that change this antenna gave me a used rotor (which I think was a big mistake) I don't want to go back to him again. I don't think I can trust him. Could someone recommend someone in the GTA to do this work. Someone they have dealt with recently and are reasonably priced? |
#17 |
There was one more thing I wanted to add, if I do upgrade the antenna will it be possible to get the Rochester locals? I ask this question before, but I believe with a 50' tower I should get something. I am at Victoria Park & Sheppard, so I am fairly east.
#18 |
I called Channel Master and got confirmation that
the load rating of the 9521 rotor is not designed to support two antennas in a stacked configuration. For those who have used it it may work but it will put additional load and stress on the motor. I dont know how much or fast it would reduce the life expectancy of the motor especially during our winters when we have heavy winds and may also encounter ice build up. What he suggested was to use a load bearing support. ![]() I don't think we have to use the guide wires if the pole is enough to mount both antennas. ![]() Stark sells them for $20.00 http://www.starkelectronic.com/rotor.htm#tb105 This spring I might try stacking 2x4228 to test if I can get WB49. If I can't get WB49 I will end up using a single 4228 antenna, as I currently get excellent reception from Buffalo and Toronto.
CM4228/9521/7775;F.RmJvc70FH96/8300HDPvr/Dish 612;B.Rm LC52LE810UN/8642HD;Study LG50PK550/Xbox360; |
#19 |
DHC Supporter
Thanks for the load resolution Yaamon...had quite a storm come thru last night and my rotor very is erratic this morning. I will look into a new rotor and mast support you suggested. Thanks again, Joe
http://community.webshots.com/myphot...ecurity=diSsqS |
#20 | |
Joe, if you think you might need a stronger rotor than your OTA TV model check out Burnaby Radio for a quote on one of their Yaesu HAM Radio rotors: http://www.burnabyradio.com/dhtml/index.html HAM rotors can be really expensive compared to most OTA TV gear, but they sure do the job for anyone thinking of running stacked arrays or dual/triple antenna mounts, and the higher end ones have a fast and slow variable speed control for precision slewing: http://www.yaesu.com/?cmd=DisplayPro...&ProdCatID=104 Any HAMS out there who prefer or recommend other brands or can vouch for the Yaesus? |
#21 |
DHC Supporter
Before I return my new 9521a rotor I'm asking for help.
Ran sync a couple of times and everything was fine then just before assembling antenna outside I tried the sync again...it homed north fine then stopped at 227 degrees on return. So now instead of going to 360 it stops at 227. I have unplugged power and did a clear memory 91dn arrow with no results. Thank You for any help...Joe. |
#22 | |
#23 |
DHC Supporter
Thank you for pointing ME in the right direction Stampeder...not sure how 227 degrees got programmed into the controller but entering 360 continued the complete sync. Working fine now. Thanks.
#24 |
The ArcherRotor brand name sold by Radio Shack were all made for them by Channel Master. Many of the rotors here use a 26vac 2-phase AC motor... The motor will have three connections; common (ground), and the two phases... In the controller unit there is a 130-uf/50vac capacitor connected across the two phases and the 26-vac signal is then fed to one or the other motor phase connections... The other motor phase is developed through the capacitor...
#25 |
Never noticed till now, had antenna installed over 8 yrs ago !!!! When I turn the rotator counterclockwise (north to west) My antenne actually turns clockwise (north to east).
I have a channel master 9510A rotator with 3 wires connected to it. connection #1 (black0 #2 is (red) and #3 is (white). Do I only need to change teo of the wires to make it rotate the oposite way ? Which ones ? |
#26 | |
DHC Supporter
Joe. |
#27 |
Jay....
Thanks works (rotates) properly now. Didn't want to (test)change any wires in case I damaged the unit. Best to ask first. |
#28 |
Since Nov and the cold weather I had to reposition my antenna at 160' for max signal on Nbc.
A few times at this position Fox would fluctuates enough on the Samsung tuner that it would pixelates and drop out, but fine with the LG and the tuner in the Jvc tv. Since then I have rewired the feeds to the recievers. Before was using a 2 way splitter one feed for the bedroom LG with 2 more 2 way splitters to cut down the signal to the Lg. The other feed going outside and into my basement into a 3 way splitter. The 3.5db port going into the Jvc tv and one 7db port going to a Dish 811 with attenuators totaling 9db. The last 7db went into the Samsung 451 and loop out to a Ati HD card. I rewired it two weeks ago that a 3way splitter in the bedroom and the 7db into the LG. The other 7db output to the Dish 811 with the same attenuators 9db. The 3.5db into the basement into a 2 way splitter one going to the Jvc and the other output going to the Samsung. Basically the Samsung gets -7db of signal vs -10.5db. This was not a big deal since I dont really watch the Toshiba tv in the basement where the Samsung 451 is connected. Anyway I decide to try and move the antenna towards 175 to 180' last week and it would not turn in any direction. Brought home a new rotor on Friday from work and was going to get up on the roof on over the weekend and change it. Tried to move the antenna Sat morning, it did not move. I decide to try again to move the antenna, this was around 1pm and it moved. The antenna moved. Is there a problem with the 9521 rotor kit, as this is the second rotor that does not move well when the temp gets below freezing. The other rotor when I took it down there was no rust or water inisde the housing. The seals on the rotor is fine. Is there anything that can be done to improve the performance, better sealing ? I emailed channel master today to see if there is a bad batch with the rotors.
CM4228/9521/7775;F.RmJvc70FH96/8300HDPvr/Dish 612;B.Rm LC52LE810UN/8642HD;Study LG50PK550/Xbox360; Last edited by Yaamon; 2006-02-13 at 05:27 PM. |
#29 |
My rotor refuses to move for the past few weeks, at night, it worked once during the day i assume the sun might of helped. I just bought this thing in November, so your not the only one.
#30 |
I havnt had any problem moving my rotor atop the 60' tower, It could be there has been moisture inside and has frozen.
Panasonic PT47WX53, Humax HFA100, Denon AVR 1610 surround, CM4228 Antenna, WD TVlive |
