Antennas Direct OTA Antennas & Gear - Page 30 - Canadian TV, Computing and Home Theatre Forums
Old 2012-05-15, 12:53 PM   #436
lithOTA
ADTech, I just wanted you to see what kinds of crazy things people are doing to your "children"...
I was trying to use stagger-stacking to cancel out an offending co-channel from behind. It didn't work beacuse the power difference between the two stations is just too great, but the exercise did produce a big rear null on the target frequency and several stations a few channels away.
I'll say this about a pair of C2s (or a taken-apart C4)- they are great for experimenting with special combinations like stagger stacks and the "two-antenna trick" described on HDTV Primer.
TV Fool Report:
http://www.tvfool.com/?option=com_wr...4033e5a566a704
lithOTA is offline
Old 2012-05-15, 01:46 PM   #437
roger1818
^^^lithOTA, it may be just the angle the picture was taken at, but it doesn't look like the 2 coax feeds are the same length. Was this intentional? Normally you would want them the same length, unless they are carefully measured to phase shift one antenna, but I don't know why you would do both that and a stagger stack.
roger1818 is offline
Old 2012-05-15, 08:50 PM   #438
rabbit73
DHC Supporter
The two lengths of coax must be different for stagger stacking to work properly.
I quote from pages 186-187 of TV Antennas and Signal Distribution Systems by M. J. Salvati:
"Stagger stacking is a special variation of vertical stacking in which one antenna is mounted one quarter wavelength ahead of the other (Fig. 8-8). The cable section connecting the forward antenna to the signal combiner is made an electrical quarter wavelength longer than the other so the signals from the front are combined in phase. Signals arriving from the back, however, are 180 degrees out of phase and thus cancel. This results in a very high front-to-back ratio, even if the front-to-back ratio of the antennas is very poor. When this technique is used on antennas having a high front-to-back ratio to begin with, the rearward pickup of the array is virtually zero."
I think lithOTA did a good job of using what he had on hand to make a valid test.
Well done, Mike!
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
rabbit73 is offline
Old 2012-05-15, 10:48 PM   #439
roger1818
^^^Oh, OK. That makes sense! Wouldn't you need to compensate for the velocity factor of the coax when making it 1/4 wavelength longer though? I guess that is what they mean by electrical quarter wavelength.
Old 2012-05-16, 12:54 PM   #440
ADTech
Well, I'm more a "step-uncle" for most of these things... I'll show your photo to the "Daddy", he'll get a kick out of it.
Pretty cool!
ADTech is offline
Old 2012-05-16, 07:27 PM   #441
rabbit73
DHC Supporter
Yes, that's exactly what he did, using the velocity factor of 0.85 that was specified by the manufacturer of his coax.
The wavefront of the incoming signal arrives at the upper antenna sooner than the lower antenna, so you need the extra coax to act as a delay line so that the signals from the two antennas arrive in phase at the combiner.
rabbit73 is offline
Old 2012-05-16, 08:05 PM   #442
roger1818
^^^Sorry, I didn't see any mention of velocity factor in his original (or suubsiquent) posts.
Old 2012-05-17, 02:30 PM   #443
rabbit73
DHC Supporter
No problem; it took me a long time to go through his posts because I was very interested in high F to B ratios after trying to help Balm with VHF-hi WVNY reception at his summer cottage in Saint Anicet.
rabbit73 is offline
Old 2012-05-28, 04:10 PM   #444
threeflags
How's the DB4e for FM reception. Seems to work but I'm noticeably missing 2 strong local stations from Toronto (about 40 miles away). From those nearby, the 2 stations are CHUM(104.5) and the Q107.
threeflags is offline
Old 2012-05-28, 04:44 PM   #445
roger1818
^^^The DB4e will be about as good for FM as it is for VHF-LO and that is very poor. Strong broadcasts will be receivable by anything, but you will be better off with a simple FM folded dipole.
Old 2012-05-29, 12:12 PM   #446
ADTech
Roger is quite correct. UHF antennas will work for FM about as well as the power cord on your bedside clock radio. Short-range reception is usually okay, but beyond that, a real FM antenna should be used.
ADTech is offline
Old 2012-05-30, 04:10 AM   #447
ppauper
I apologize if this is in the wrong thread
(US) Walmart is now selling 2 Antennas Direct HDTV antennas , ClearStream Micron and ClearStream1
Walmart Embraces Cord-Cutting Movement
ppauper is offline
Old 2012-05-30, 10:49 AM   #448
ADTech
Please note they're being positioned in the aisle with the Roku-type products instead of with the other antennas and accessories.
Individual store setups may vary.
ADTech is offline
Old 2012-05-30, 11:15 AM   #449
roger1818
ADTech, any idea if it will come to Walmart Canada? It would also be nice if they sold the indoor C2 (and C2V) as well.
Old 2012-05-30, 11:20 AM   #450
Blackburst
Need some advice for the DB2e and the DB4e
I've used a DB8 in the past. But since I've moved recently, I have a DB4 temporally placed at a window picking up all the Montreal stations (except for CFJP-DT 35.1) and also WCAX, WPTZ and WCFE from the US. Not bad really for a indoor window placement.
Summer time is here and it'll be time to do a proper roof top install. I'm in a Condo building that allows Dishes and such on the roof. So no problem.
But, at the same time, I would like to use a small footprint antenna on the roof.
The question is which one. Would a DB2e be good enough to replace a DB4, or would I require a DB4e instead. I won't use the DB4 I have as I have promised it to somebody else.
The set up would be on a six storey building. No obstructions, can see Mount Royal, and have a clear path towards the US. The only thing that concerns me is the airplane path as they prepare to land at the local airport. But that would be on the back end of the antenna. The RG6 run would be 6 floors down, and then another 30 to 40 feet back up.
Comments, Suggestions appreciated.
Blackburst is offline
OTA Forum Sponsor
