Digital Home Canada
Go Back   Digital Forum > Digital Forum Help and Administration > Archives > 2002 and Prior
Forum Favourites Help Register Calendar Search Today's Posts Mark Forums Read
Old 2002-12-23, 09:25 PM   #1
c86chris006
Default video games on my hitachi ultrascan hd
could i play video game slike playstation 2 on my hitachi hd with out damaging the screen??? :roll:
c86chris006 is offline
Old 2002-12-23, 09:31 PM   #2
hugh
Digital Home Founder
yes. Like any set, you should have your set calibrated and beware of games that might have a constant image that could cause burn in on your screen.
Check out the Home THeater, HD forum and HT FAQ forums for more discussion about burn in.
hugh is offline
Old 2002-12-24, 08:06 PM   #3
apw100
Default Games and contrast settings
Make sure that your contrast is set below 50%(25%-30% is ideal). Keeping this down will help prevent burn in. Since most people dont play the same game for more than a month or so, I dont think burn in from the game's static images(i.e.- Health bars, points, displays,etc.) will be of much concern. Just dont pause the game for long periods of time while the tv is on. Have fun!
apw100 is offline
Old 2003-01-08, 06:34 PM   #4
F.Kastle
Some games will force you to use Standard 4:3, so my question is "Is it ok to play the game with BLACK SIDE PANELS and not the default grey ones? I heard that the black burns the screen.
On the other hand I also heard that the thin black lines along the grey side panel can potentially burn the screen too.
Sorry for being paranoid , I just want to make sure my Hitachi lasts before I have to pitch another 1000$ into her. :roll:
Hitachi 51SWX20B : Technics Reciever
Panasonic DVD : GameCube : PS2
F.Kastle is offline
Old 2003-01-08, 08:26 PM   #5
apw100
Default Black Bars
If I was you, I wouldnt use the black bars as they WILL cause burn-in eventually. As for the grey bars, as long as you keep the contrast down, you should be ok. I know that most games make you play in 4:3 mode, but if it doesnt bother you that much, use one of the stretch modes on your tv(4:3 Expanded, or 16:9 Standard). The picture will be a little squashed, but if you can handle that, at least you wont have to worry about burn in. Also, I would consider getting an XBOX. There are a few games out right now(Tony Hawk4, NBA2k3,etc) that can be played in true HD resolutions in 16:9 format. There are supposed to be alot of new games that support HD on the XBox this year. Something to think about....
apw100 is offline
Bookmarks
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
