Location: Bowmanville, ON. Antenna: Channel Master 4228; Rotor: Zenith ZENRTR1; HD Tuner: Samsung SIR-T451
How weird is this...
Prior to my putting my Channel Master 4228 antenna on the mast, it was LYING DOWN on the roof. I went inside, happened to check the TV, and was happy to see that I got a bunch of channels already. But then, once the antenna was vertical, I LOST SOME!! No amount of rotation, for the past 2 weeks, has gotten them back. That meant that the antenna did better (for some ch's), lying on an averagely-sloped house roof, say 20 deg from straight up. So, is it normal for the VERTICAL angle of an antenna to make a diff? Or just the rotated direction? And most importantly, what can I do? Has anyone ever angled their antenna up a little bit? Maybe by using a piece of wood? These are the ones that were 'catchable' when the antenna was lying down: 7-1 WKBW [it would be my first ABC] 29-1 Fox WUTV 29 29-2 Fox WUTV 29 29-3 Fox WUTV 29 21-1 WXXI 21-2 WXXI 21-3 WXXI 21-4 WXXI |
The two-word reason for weird reception by a horizontally placed antenna is multipath interference. TomF.1 already gave you an excellent response in post #47 of the ON - East of Oshawa to Ottawa - OTA Results thread (yours is #45):
http://www.digitalhomecanada.com/for...ad.php?t=33034 Also here's a post on antenna tilting from the OTA Installation Tips And Tricks thread: http://www.digitalhomecanada.com/for...3&postcount=80 |
My dual PR-8800 array works better tilted than non-tilted, when trying to bring in the very-distant PBS station from Norwood. I've not measured the angle, but it looks to be about 10 degrees upward from vertical.
Cheers |
