BC - City of Vancouver, North Van, West Van - OTA - Canadian TV, Computing and Home Theatre Forums
Old 2005-04-13, 12:53 PM   #1
stampeder
Lightbulb BC - City of Vancouver, North Van, West Van - OTA
This thread is a one-stop-shopping location for info on receiving Over The Air High Definition and Digital broadcasts only in the cities of Vancouver, North Vancouver, and West Vancouver, as experienced by Digital Home Canada members.
In your posts please specify:
1. Your Location (city, town, locale, on a high rise, in a valley, etc...)
2. Receiver and Antenna Brand/Model
3. Stations Received with their Picture Quality (excellent, pixellated, etc...)
4. Other helpful info...
stampeder is offline
Old 2005-04-13, 01:19 PM   #2
stampeder
Default Vancouver/Victoria OTA
The countdown to local OTA in the South Coast area of BC is now centered around CBC DT 58 going live up top of Mount Seymour some time in 2005. No word on CTV, Global, CH, CITY, VI, or others lately.
I've been doing some research and have been getting feedback on a different web forum regarding some of my ideas for U.S. OTA reception in the Vancouver area. Before I begin, bear in mind that some of you are not going to be happy with my findings.
Here's a useful map for seeing the layout of the area. An essential tool for figuring out OTA reception potential is AntennaWeb, which unfortunately only provides data for U.S. locations. No problem because you can use the closest Washington zip codes and extrapolate from there.
For Victoria and the southern tip of the island I would use the Port Townsend, WA zip code (98368) and factor in a much weaker signal strength due to the distance being almost double. Bear in mind that its not certain that you might be able to see around the Olympic Mountains towards the SeaTac corridor.
For the Lower Mainland if I was in S. Delta, Richmond, or Vancouver I would enter the Point Roberts, WA zip code (98281). Low lying areas will not do so well, and anyone on the north slope of a hill in Vancouver will probably not have much luck.
For anyone on a south-sloping hill in Burnaby, Coquitlam, PoCo, N. Delta, and Surrey I would use the Blaine, WA (98231) zip code, although Blaine is pretty well just above sea level so you would need to take the extra distance into consideration as a negative, but the extra altitude as a slight positive. Your results may vary. People on north slopes in those places will probably be out of luck.
I suspect that most of New Westminster will likely be in a dead pocket due to the signal shadow of North Delta and North Surrey, but people in the upper suites of the high rises on the southern facing sides might have luck. Likewise I think Maple Ridge, Abbotsford, Langley, all the way east through to Hope would have the same problem with the mountains to the south of them.
I also think lower parts of North and West Vancouver are going to be in a shadow effect from Vancouver and Point Grey but people in high rises above the 10th floor or so may have some luck. I have my doubts about anyone in Gibsons or Sechelt getting strong enough signals.
Old 2005-05-12, 05:23 PM   #3
stampeder
Thumbs up CTV Vancouver Live In DT Today
Today CIVT-DT (CTV Vancouver) went live on UHF 33-1, and as I type this at 14:20 PDT they're running the same programming as on their analog station but the audio is in Dolby ProLogic instead of PCM @ 48. The digital signal is strong at times but then cuts out while they tweak it.
Old 2005-05-16, 11:53 AM   #4
Jeffnoone
Default North Vancouver
Wanted to get a few comments on my specific situation
Live in North Vancouver, about 7 miles from Mt Seymour
With regard to local transmission of CTV and others from Mt Seymour, I unfortunately do not have line of sight to Mt Seymour - I am in the Edgemont Village area, so the crest/ridge separating the Lonsdale area from Lynn Valley blocks the view
Can I hope to get CTV?
I assume these signals cant bend, but can they bounce (off statosphere?, or of signal towers elsewhere?
I know multipathing can occur - how likely I can avail of this reliably?
With regard to signals from the US, my elevation is about 360ft. so the crest of Vancouver City might block signals from the far South e.g. Seattle area - any comments on this, beyond the copmmnets already here on Vancouver being a fringe area, and the fact that N Van is another 8-10 miles further north from places like Delta where Stampeder has made observations. I can tell from one of these mapping programs that the signals would be coming to me over the Killarny Park Joyce Stn area of Vancouver City itself, which has an elevation of about 340 ft
Is there any possibiltiy of the big networks from Seattle having booster towers up towards Bellingham? Is this a legal issue?
Jeff
Jeffnoone is offline
Old 2005-05-16, 01:34 PM   #5
stampeder
They use small repeaters at very low power levels throughout WA but none that you'd pick up. Repeaters are used by local community groups to fill in dead zones or other places where signals drop off. There are a few to the east of Bellingham but they're tiny and isolated in valleys around the Mount Baker area.
I think those of us in the Lower Mainland are unfortunately at the extreme fringes of SeaTac UHF signal, especially given the amount of sea moisture in the air causing further UHF signal degradation. I'm going to keep trying from where I am in North Delta. Anyway, Global will jump on the DTV bandwagon soon, and CBC is going digital in September. More locals will follow in 2006.
Regarding CTV's signal, I would test for UHF 32 (CTV analog) with a cheap set of VHF/UHF rabbit ears since you're so close to their broadcast antenna. If you get a good signal its probable that you will also get the digital station on 33. If it didn't work out, no big $$$ spent.
Old 2005-05-25, 12:36 PM   #6
stampeder
Default CITV-DT (CTV Vancouver) remapping
I noticed on May 24th that CIVT-DT Vancouver, which broadcasts on 33.1, is now remapping to 32.
Old 2005-05-27, 02:45 PM   #7
madbob
Default Vancouver Near UBC
Yes, I`m having some luck. With the 4228 and a Winegard 4800 pre-amp on a rotor I`m getting,
CTV 85%
KBCB 95%
KCTS 50-60%but get dropouts
KVOS 50-60% but get dropouts
KSTW 50-70% but get dropouts
KING 55-85% but get occasional dropouts
KOMO 50-75% but get occasional dropouts
Have not been able to get KCPQ or KIRO.
I have lots of trees in the way, so I`m getting mutipathing. If I can find a 30ft.
ladder I will be able to do a chimmney mount which will get the attenna about
10 ft. higher than it is now, which should give better performance.
I`m located near the UBC area of Vancouver.
madbob is online now
Old 2005-05-27, 04:26 PM   #8
madbob
I have a Sony 34XS955 tv which has a built in tuner. I hope to do the chimney mount in the next week or two. It will be interesting if I can receive the Seattle channels in the winter rain.
Old 2005-05-28, 12:46 AM   #9
dbarron
Default Vancouver CTV-HD with a cheap loop antenna
Just out of curiosity, I put a cheap old UHF indoor loop antenna on the roof desk vaguely oriented towards the transmitter on Mt Seymour, connected it to my BEV 6100 via a 50 foot length of RG6, and tuned in CIVT-DT channel 33 (CTV HD W). To my suprise, it came in at 75% signal strength and a rock solid picture and sound. I guess I shouldn't be suprised since we have a clear line of sight to the transmitter.
We really don't watch much that we couldn't get from the local stations. I would love to drop satellite/cable go strictly OTA. The money saved would pay for a dozen DVD rentals every month, more than we would ever watch.
I wonder if there is a relatively inconspicuous or at least non-hideous outdoor antenna that the neighbors wouldn't absolutely hate? The satellite dish on the roof deck points southish and can be hidden from the neighbors on our side of a low wall, but a TV antenna would have to be put on top of the wall to point at the transmitter and would be vsible to the neighbors.
Dave
dbarron is offline
Old 2005-05-31, 04:28 PM   #10
madbob
Just an update on my reception of the Seattle stations, I think the only reason I was recieving them was because of skip, because I can`t get them any more, not even KVOS.
I`m still getting 90% on CTV and 95% on KBCB from Bellingham.
I`m still going to mount the antenna higher to get more gain, to see if I can pull in the Seattle stations.
Old 2005-06-02, 06:39 PM   #11
4DTV HD
Originally Posted by mingus
Hi All,
I am thinking of buying a new HDTV with a built in digital tuner.
I live on the North Shore in North Vancouver BC.
I was wondering how many HDTV channels I could get with a small antenna.
I am not sure if there is one or two Vancouver stations testing.
I see a list of some USA stations?
This is the TV I am thinking of buying.
"Samsung 30 in. SlimFit™ HDTV with Built-in HD Tuner"
Any comments would be appreciated.
We don't know your elevation in N Van but the higher you are the better.
CIVT-DT(CTV) is currently broadcasting, CBC has said they will be on this September and BCTV is saying next year. These are all short range stations which you should be able to get with a small antenna. If you can see the lights on Seymour Mountain, that's where the transmitters are.
To have a chance of getting the US stations you will need a larger antenna such as the CM4228 and a preamplifier.
Information on Digital channels available in the Pacific Northwest can be found here: http://members.shaw.ca/nwbroadcasters/digitaltv.htm
4DTV HD is online now
Old 2005-06-02, 06:45 PM   #12
Jeffnoone
In my situation, the slopes of Grouse Mt block me from Mt Seymour, where I gather most (?all) of the local broadcasters will broadcast from. My elevation is about 400ft - see my post earlier in thread where there is reference to the height of Vancouver City itself
Using the small UHF antenna that comes with the ATI HD Wonder, and the Expressvu 6100 as tuner, I get a very patchy 50-60% on both CTV (Mt Seymour) and same reading on KBCB (not hi-def)
So I get an intermittent picture
I will get a 4228 or equivalent type antenna and I would assume I will get the Mt Seymour broadcasts OK
The posts here to date make me more gloomy re the Seattle HD channels - the North Shore is 120km out, 4DTV is about 100km from downtown Seattle - his unobstructed height and his relative proximity probably make a big difference
If you are high up, I would be interested in seeing your results
Old 2005-06-05, 10:38 PM   #13
stampeder
Default North Vancouver Antenna Recommendations
In your case you could even use a 4-bay reflector like a Wade-Delhi 4BT-1483, a Winegard PR4400, or a Channel Master 4221 if your goal is just the Vancouver stations and you don't want an imposing antenna up on your roof. Avoid using a yagi in your situation because of the obstruction (they're for line-of-sight). All of those I listed are bowtie reflectors that will be able to pick up the scattered signal coming from around Grouse. If you're intent on trying for SeaTac the 4228 is a needed first step, but a 4228 would also do just great for the Mt. Seymour signals.
Old 2005-06-17, 03:26 AM   #14
stampeder
Hey madbob: any difference with the higher antenna?
Old 2005-06-17, 12:07 PM   #15
madbob
No difference at all. The signal meter still shows 9-10 db signal on KING and KIRO, but not enough signal to lock onto. I have a lot of trees in the way. I tried going up the chimmney using a 40 foot ladder but got spooked working up that high. I`m getting the house painted now and the painter said he would install the chimmney mount for me(he has to go up there anyway). This will raise it another 5-10 feet, so I hope it helps.
OTA Forum Sponsor
