#1096 | |
Throw out the HD amp. Seriously. Lol. Any amp you can find in HD/Rona/Lowes/etc is most likely crap. I had an HD (RCA) one and switched it for a CM one and it's far better. |
#1097 |
Location: Whitby, ON -- Rogers, SA 8300HD, Sony KDL-52W5100 LCD, Panasonic BD35, Panasonic SA-XR55
Hey, I am not gonna throw it out, I paid for it, it is being returned...
#1098 |
I didn't mean literally throw it out :P
Just, you're probably better off not using it at all.. |
#1099 |
Curious what the forum consensus is on the best antenna for Buffalo channels.
Currently I have a 4221 (original) & get Batavia (ION) thru Buffalo. With the preamp, interruptions are very rare. From my house, that is a 28 degree swath. I'm replacing the (separate) antenna I use for Toronto stations though - so I have the option of using the 4221 for Toronto and buying another for Buffalo. For a 28 degree wide beam (ION & FOX on either side do require some good capturing) my antenna guy is advising that I would lose ION with a 4228. Does anyone have any strong feelings either way here? |
#1100 | |
My favorite antenna is the DB-8. Wider pickup and more gain than the 4228HD and needs no modification. I've done a couple installs where the client replaces his 4221 with a DB-8 and he's amazed at the difference.
#1101 | |
Hey, another q. Who here gets Rochester, and how. I believe two of the three stations are VHF, no? |
#1102 |
I get rochester most evenings in the summer in Ajax, though WXXI is by far the most regular of the three I have received in the past. This is the first spring here though with the antenna setup, so I'll see how things go as the trees fill out again. So far this time of year has been really hit and miss, and depends highly on tropo activity. Winter is a complete writeoff for any of them. Even when I have fairly good reception, I have to use a rotor to point my 4221's right at Rochester to keep it locked except for the strongest tropo days.
#1103 |
Hi all, I am located east side Oshawa, west side of Courtice, just past townline rd and Hwy 2. I have 2 CM4224's mounted on a 40ft tower. 1 towards Toronto and the other pointed at Buffalo. Untill a month or so ago I could get all the Toronto/Buffalo stations (18 or so). Now reception is more or less gone
At times toronto comes in for a bit, same with buffalo, most of the day/night the reception gone. Just to torment me, last week about 10pm all the channels were back (with the exception of 51, it is a long way away). Got up the next morning.....all gone again Anyway, my question is this related to the sun spot activity? Is reception generally bad at the moment? The set up worked solid for years. Had the thought of getting cable, that's when I figured I needed help Any ideas as to whats going on? Thanks........Rob |
#1104 |
Rob I assume your 2 antenna feeds are joined together,so if 1 develops problem it will effect both.Also combining always weakens the signals from each.Reception for me is always fine except for 51.1 which is weather dependent.
CM 4248 at Buffalo,XG43 at Toronto,M4 at Buffalo,CH 11 yagi at Ham. |
#1105 |
Trouble with WNED last night. Anyone else have that, or do I have another problem?
Kinda disappointed, because I had just moved my preamp (Kitztech) under the antenna (4221) from it's old location behind my TV (and the wrong end of the cable). The Kitztech is good, but it appears not to care what end of the cable (90') it's on. |
#1106 | |
Basically, if all the channels you receive are at least 20-25 dB above the noise floor, than you won't see the improvement that a Kiztech preamp would provide someone else whose signal environment is on the hairy edge. It just means that perhaps you odn't need such a good low-noise preamp (or maybe you only need it on the "worst" days. And perhaps last night was so bad even the Kiztech wouldn't help you.) |
#1107 |
I currently have a 4221 (the old one) preamp'd with a Kitztek & have occasional fallouts - PBS on one side an ION on the other, 28 degrees apart.
Is there a better option for a somewhat multidirectional antenna? I read the DB8 wold be a good option - the high gain of an 8-bay with a wide beam - but futher research indicated this might just be marketing & the db8 is actually quite directional, even more then CM's 8-bay, the 4228. ![]() I was thinking one option would be to get the db8 & "bend it" somehow so each 4-bay is pointing in a slightly different direction - but perhaps I'm NUTS? |
#1108 |
I think i suggested this in another thread, I looked up your tvfool report.
NBC says -70 LOS, Ion says -102 2edge. If you want Ion, get a xg91 and a rotor, or a switch.
#1109 | |
We record all of our shows so a rotor is *not* an option - my htpc can't turn the rotor prior to recording the show. What I'm looking for is the best multi-directional antenna out there, for 28 degrees of separation. My 4221 is very good, inturruptions on PBS or ION are actually quite rare, but I'm always looking for ways to improve. |
#1110 |
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
If your old 4221 can reach the distance, then a new 4221HD [hacked for a wider beamwidth] should work for you. Removing the plastic caps and flipping the balun phase line is the basic hack, but the down side of hacking the reflector width could cost some distance in some circumstances.
It would be a relatively cheap experimental expedition ! Being so close to the CN tower and CTV's BarberGreen broadcast locations, I presume that a hi-gain preamp is out of the question. |
| Tags |
| ota hdtv |
