#346 |
yes i do have a preamp and cant remember what it is but i do know it amplifies uhf more than vhf. it is a master channel with 300 ohm in and 75 ohm out.
200 feet higher ? how did you get so high? - i think one of my problems is between me and the cn tower i have a high voltage line in my line of sight. |
#347 |
#348 |
I don't know the angle sort of south/south west i just played around and found the best spot. The 4228 is on a mast 6 feet above my 2 and 1/2 story house. Electro my house is near St.Clair, all up hill from your place and a clear view south and west, no amp on my 60 foot run of cable.
#349 | |
#350 |
After reading these forums for a few days I decided to give it a shot. I'm in north Whitby (Brock/Dryden area), and just using a cheap RCA indoor antenna in my attic I'm receiving the following:
2-1 WGRZ HD 2-2 WGRZ SD 4-1 WIVB HD 5-1 CBLT DT 7-1 WKBW HD 7-2 WNGS SD 7-3 WCSN SD 9-1 CFTO HD 11-1 CHCH DT 17-1 WNED HD 17-2 WNED SD 17-3 WNED Th 23-1 WNLO HD 25-1 DBLFT HD 29-1 WUTV HD 29-2 WUTV SD 36-1 CTS HD 41-1 CIII HD 44-1 OMNI2 HD 57-1 CITYHD HD 64-1 OMNI1 HD 66-3 SUNTV HD Unfortunately I can't put an outdoor antenna up, but with these results, I'm not sure if I'm even going to bother with a Channel Master, or building a Hoverman to put in the attic... Thanks for everyone posting in the forum, I would have had no idea I could do this! Last edited by N_Whitby; 2008-06-27 at 07:37 PM. |
#351 |
But is it one that you have to plug in and turn on? Isn't it on all the time then?
That's great though. |
#352 |
No, it's not powered... It looks like this:
![]() and just using the ATSC tuner in the TV. |
#353 |
Just to let you know - Summer is the golden time for reception.
I have found that once it gets to fall - winter, you get a lot more dropouts, especially with an indoor antenna. Just keep that in mind.. you might be looking for an outdoor solution come October-November |
#354 |
Are you sure? On my antenna, I was able to pick up city and even fox showed up when it was really cold. I'm not pointing in the right direction, this is why I'm skeptical to that comment.
#355 |
Toronto stations stay fine, buffalo are the questionable ones - ex. right now I receive MyTV quite easily.
In the winter, that station is nonexistant to me. Also fox, NBC, ABC are not the best in the winter for me (like.. 85% uptime, maybe? Vs 99% in the summer) CW can probably be picked up by a bare cable, so that's not a trouble station at all. |
#356 |
I'm in Ajax and I recently had my CM 4228 installed on my roof by forum member Yaamon here, great service by the way - fast and honest guy. Facing south exactly at 180 degrees on the rotator, here are the stations I receive:
2-1 WGRZ-HD (100%) 2-2 WGRZ-SD (100%) 4-1 WIVB-HD (100%) 5-1 CBLT-DT (100%) 7-1 WKBW-HD (100%) 7-2 WNGS (100%) 7-3 WCSN (100%) 9-1 CFTO HD (100%) 17-1 WNED-HD (100%) 17-2 WNED-SD (100%) 17-3 WNED-Th (100%) 18-1 CHCH-DT (100%, on & off depending) 23-1 WNLO-HD (100%) 25-1 CBLFT-D (100%) 26-1 WNYB-DT (100%) 29-1 WUTV-HD (100%) 29-2 WUTV-SD (100%) 36-1 CTS HD (100%) 41-1 CIII-DT (100%) 44-1 OMNI 2 (100%) 49-1 WNYO-HD (100%) 49-2 WNYO-SD (100%) 57-1 City HD (100%) 64-1 OMNI 1 (100%) 66-1 CKXT-DT (100%) |
#357 |
Uhhh..
Great results.. except I think your signal meter could probably be a bit more accurate.. It would be more helpful if it was more precise in its measurement.. I doubt all channels have the exact same signal level (actually, I think thats near impossible) |
#358 |
100% signal strength right across the board... Yaamon is amazing!
Just kidding about those numbers - were all those results with your ATI card, DearRicky? Its not realistic for all of them to be at 100% so I'm just curious. |
#359 |
The results do come from my ATI-BeyondTV configuration. I'm still not sure why I'm getting 0 for CIII-DT because the picture quality is just like all others (even with other programs such as Catalyst Multimedia Centre and SageTV), but with CHCH-DT it all depends on the time of day.
Here is a screenshot:
#360 |
Try watchhdtv, its freeware.
It's signal meter isn't calibrated for all models, but it will give you a very accurate number. (in my case its like 7 digits, but that's a fluke, lol) |
| Tags |
| ota hdtv |
