Is it possible to move picture up and down when using zoom on 8300HD ?
Only if your TV provides the feature. Mine does - check yours.
SA8300HD; Panasonic TH-50PZ850; Sony STR-DA5ES; Tannoy: Arden, S8C, S8LR; SVS 16-46PC+; Oppo 971; Harmony 659/680 |
There is a zoom feature on the 8300HD box? How do you operate it? I wasn't aware it had this feature.
#4 | |
Which should be obvious to anyone, because when I see a key marked with a pound-sign I, of course, think zoom. Sheesh.
Toshiba 62HM84 | SA 8300HD | HD-DVD/Blu-ray HTPC | XBox360 | Playstation 3
Denon AVR-2807 | URC MX-650 |
#5 | |
You can't use the SA STB to move the picture up/down.
I believe the "#" key is documented in the operating manual. Also you can click settings button once and scroll up to picture size. I always go through ALL of my User settings on all my electronics to see what all the functions do, to ensure that they are properly set up. I don't know why other people are not as curious, but they don't use their electronics to their fullest I guess.
Ghost, on my Sony TV, it's under Menu > Setup > Vertical Correction.
#8 | |
#9 | |
#10 |
Ghost, on my TV, the "Vertical Correction" parameter is global and is under a different menu. In HD mode, all my zoom settings (including Vertical Center) are greyed out just like on your TV. You need to look for a similar parameter but in a different menu (other than the screen zoom menu).
#11 | |
And 57 confirmed that SA STB can't move zoomed picture |
