#16 | |
Samsung LN52B750, SVS PB12-ISD, Harmony One, HD-A1, BDP-1400, Oppo DV-970HD, Zektor HDS4.1 |
#17 |
In Gatineau the PQ looks like it was better in the holidays than now.
A videotron tech. came over and checked things out. He says the "tuner dBmV" rating is not important...that it is the FDC dBmV we should look for. Anyway my FDC is 9 dBmV on all channels (SD or HD), but the Tuner dBmV is different as a flip from one channel to the other. I verified and figured out that the "tuner dBmV is the same as "current QAM". That number will range form -6 to +11 depending on the channel. I remember looking at PBSHD before Jan 1st and current QAM was +4 ...now its steady -3/-4 and I find the PQ has degraded since the Xmas holidays (Gatineau region). The tech also tells me that "all"service guys prefer the SA HD STB over the Pace HD STB. Anyone has an opnion on the numbers I put forward and the SA vs Pace thing?
PACE551-Toshiba57HX84C-SonySTRDE595- 5.1 Acoustic Research S50 |
#18 |
Jlack,
I had a problem with an unstable signal such as you seem to have. The first tech (private contractor) did a splitter change in the house and although this enhanced the signal strength, he noticed that the signal was still unstable (tuner 1 varied by a few dB much too quickly). He stated he would report the problem to Videotron as this was a repair outside the house. A few days later, I had a stable signal.
#19 |
JALCH,
If I understand your post above you have a Current FDC Level at +9 dBmV. I am also in Gatineau (Aylmer sector), if you confirm that this is correct I will give them a call, again. As I stated in my post above, I was at -2 before last Tuesday when a videotron contractor came in and got it up to +2 and I was thrilled, well not so anymore, when you're at 9. For anybody else out there what is your reading on the Current FDC Level and should we be complaining if it's not 0 or above? What is the average or acceptable level? Thanks In Advance, Don
LG 60PG60, SA 8300HD PVR,Sony STR-DE545 (Receiver), Sony DVD/VCR RDR-VX500 |
#20 |
My FDC is always at -11 dB and it's not a problem. I have 2 DVR's
#21 | |
Its the "curent QAM" read that fluctuates for diff. channels and different nights. Can anyone explain what is the "Current QAM" dBmV value good for if it is not to mesure some signal perf. for each separate channel? Like I said before videotron says its not important and should not be used for any interpretation. I was watching a show about death valley desert Sunday night on pbsHD and when the image was panning I would get the little mosaic blocks (on all feed...HDMI,component,svideo). Thanks.
#22 |
The current QAM should be between - 10 dB and + 10 dB with 0 dB being the best of the best. At 9 dB either way, the figure on my STB's turn to color orange.
#23 |
So then, if Jlach's Current FDC is at +9 and mine is at +2, then mine is better, closer to 0, correct?
What about you MFabien are you not on the outside of acceptable at -11 although it's Current QAM? Don
#24 | |
#25 |
Well here is an update.
After 2 tech. support calls and 2 onsite visits the problem remains. On the 2nd visit the tech had more time to spare so we watched the same "death valley" show and he too could see the little blocks on some images. The signal is just fine according to him and he thinks its a compression problem with the pace 551. Anyway he switched it for another new unit, but it did the same. They can't get any SA units because of shortage so he ended up saying to keep an eye for the next release of SA.... when it comes out demand to get my Pace replaced for a newer SA model.
#26 | |
My Tuner level was around -10ish and I was having occasional trouble (blocky video, blank screens). I removed a splitter to my VCR and all was well after that. Plus my signal jumped to -3ish.
#27 |
I am also have intermittant gray screen on my 60" SXRD with SA 8300 DVR box. The problem is intermittant, only seems to occur when the program is in High Def, generally occurs on the same 2 channels (but last night a different channel was affected). Multiple visits from the cable co (time Warner), all splitters removed from line, amplifier added, good signals, and 3 box swaps all without help. Any thoughts appreciated
#28 |
Have you checked your connections? See the Digital Home FAQ "Things to check first". Don't just check the cables, remove them, clean them, "reverse" them if possible (put the part that was in the TV in the STB), etc.
When you swapped the boxes, you may have reconnected the ends that are connected to the STB, but did you remove the ends in the TV?
#29 |
I have redone the connections several times, though not with a mind to cleaning or reversing them. Of note, my 10th conversation with time warner level 3 support higher ups has revealed that I have several channels out, all of which come on the same "quom" which is basically a chip set at the neighborhood level. THey are now working this problem and we will see where it goes
#30 |
Sounds like it could be either a head-end or "node" issue if it affects a single QAM (frequency). The service provider needs to fix this...
