PS2 and widescreen games? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Entertainment > Video Game Consoles and PC Gaming
Old 2005-12-19, 08:26 PM   #1
trellaine
Default PS2 and widescreen games?
I have an xbox but currently on the hunt for ps2 console. I notice the ps2 has component outputs. Does ps2 currently have any widescreen games available and if not, why use component? will this make much of a difference compared to using RCA cables?
trellaine is offline
Old 2005-12-19, 09:14 PM   #2
Skidz
On the PS2 dashboard you can set it to 16:9 but i cant remember if it actually made all the games widescreen,as for the components you'll need that to play GT4 in 1080i.My friend was playing GTA: san andreas on a 50 inch screen and couldn't see the mini map very well in the corner( was using the standard cable) he bought a s-video ps cable and said it cleared up.I think components are overkill for a ps2 it will cost too much and there are not enough games that will use it.You can get a 3rd party s-video cable for $10
The Older I Get,The Better I Was
Skidz is offline
Old 2005-12-19, 10:19 PM   #3
maddogmaulucci
here is a good list of games that are widescreen or at least progressive scan
http://www.hdtvarcade.com/ps2list.htm
maddogmaulucci is offline
Old 2005-12-20, 12:22 AM   #4
trellaine
Default Agree
Thanks a lot for the information. Much appreciated and I think I agree with the posting about the component probably overkill for ps2.
And I will be sure to check the link out for games.
Old 2005-12-20, 01:58 PM   #5
recycleman02
how does one get the games to go into 480 p?? I have the burnout sieres and never knew they were 480 p.
recycleman02 is offline
Old 2005-12-20, 02:06 PM   #6
Harps77
Some games will have the ability to change to 480p in the options menu, while others will ask you when the game loads, like Smash Court Tennis 2. Some games you have to enable it manually. To do this, after the Playstation 2 logo appears on your screen, hold X and Triangle on the first controller and continue to hold it. Some games will automatically load 480p, others will ask you to confirm, like SSX 3.
Harps77 is offline
Old 2005-12-20, 03:47 PM   #7
MarshallFaulk28
Wow, I just found out about this 480p trick a few days ago myself. I can't believe I played Burnout 3 for over 40 hours without knowing this trick. It would be nice if the setting was included in the in-game options (or at least in the manual how to change it). Heck, even just widescreen would have been nice compared to the 4:3. What a nice difference it makes!
MarshallFaulk28 is offline
Old 2005-12-20, 04:17 PM   #8
trellaine
Default 480?
isn't 480 standard viewing? what am i missing here?
Old 2005-12-20, 04:37 PM   #9
maddogmaulucci
480i is standard viewing but 480p or progressive scan is not.
Old 2005-12-20, 04:43 PM   #10
trellaine
Default 480p
Oops hehe right. I sometimes get all confused by technology as you can see.
Old 2005-12-20, 05:53 PM   #11
eimaj
component is definitely not overkill. if you have a hdtv and want to get the best resolution, get components. i picked up a 3rd party set set from fs for 15 bucks.
eimaj is offline
Old 2005-12-20, 06:05 PM   #12
trellaine
Default Cable?
Ok these component cables are specific to PS2 correct? I am searching FS website now to see if I can find some.
Old 2005-12-20, 07:19 PM   #13
JesseJ
Location: Calgary, Shaw Digital HD Plus, 3416 & Expander
My component cable is made for both XBOX and PS2. I got it at BB. $15.
SHAW 2012 HD Count: +8 (51 Total not counting SC or SNETWorld)
JesseJ is offline
Old 2005-12-20, 07:39 PM   #14
trellaine
Default Same
Thats interesting. Perhaps my Xbox components will work on a PS2?
I thought for sure they would make these specific to each console. Can anyone provide a link to this $15 component cable for ps2 and xbox?
thanks
Old 2005-12-20, 07:52 PM   #15
JesseJ
http://www.bestbuy.ca/catalog/prodde...63&catid=20168
Its listed for $30. Maybe that is what I paid. I know mine's a MadCatz though, same thing.
JesseJ is offline
