#46 |
So basically he should have listened to the people in this thread at the start
Windsor:CM4228+4220HD to 1.Samsung LNT3242H+2.AccessHD DTA1080D [RCA DTA800+CM7775+DTB-H260F in storage] GTA:LN40B750 |
#47 |
Hello...
I am new to the 'digital' world. The first question I asked when I saw the SA STB, "can I keep it in the basement?" I, like Alex tried to activate a third party STB with a Rogers CSR - I will keep trying. I had a digital receiver sent gratis years ago and sent it back because I didn't like the UI. The other problem I have is - I like a 'clean' setup. I find this STB unecessary. I do understand many TV don't have DTV or HDTV capability. So... I was looking towards the Samsung DTB-H260F Terrestrial DTV STB. I believe it will receive unscrambled HDTV, can anyone verify? Does anyone have the DTB-H260F and Rogers? More... I believe this issue with STB is not 'our' problem, it IS the cable companies. The signal should be 'sent' as per 'our' work order meaning billing. If I want the 30 HD channels, send 30, I could care less how you do it, just don't ask me to buy/rent your crap UI, nor hardware. They should have forseen this issue. Again, I understand majority of TV doesn't not receive DTV but that doesn't mean we need large doorstops or boat anchors to provide service, just something clean in basement, I'll decide how I entertain. I also have to agree, this is monopoly. Also, understand that we are paying for their learning curve, are 'we' entitled to share? Thanks. Just purchased Sharp LC46SE94U. |
#48 | |||||||
#49 |
alebowgm - thanks for the reply
I also understand cable companies trying to protect their signal. I'll pay for what I use. I'm saying the signal should just be sent protected. alebowgm - perhaps I misunderstood... Are you just OTA or OTA and with Rogers or other cable? Does anyone know if it would be possible to use a digital receiver (make Rogers happy) then use a third party HDTV tuner? thanks |
#50 | |||
#51 |
hi alebowgm
Sorry for the misunderstanding concerning encryprtion - I wasn't very clear. Rogers knows what i'm paying for simply send what I pay for. My problem should not be decrytpting, STBs and the sort. The only problem I should have is finding parking on the couch. Others have written here in thread that it is a monopoly, of course it is. There is no choice. I must use their UI, hardware blah blah for service. Do you recall when they splapped Billy on the pee pee because Explorer came prepacked. This is far more controlling than that. Concerning DTB-H260F - if the digital receiver decrypts 'my package' then why can't the DTB-H260F tune HD? thanks |
#52 | |
#53 |
Please restrict posts to the topic of activating an (outside) SA STB. If you wish to discuss other topics, please do so in existing or, if none available, new threads. Thanks. Future OT posts will be deleted.
#54 |
Well this thing about Rogers not activating an SA8300HD PVR that was bought on ebay is wrong, I did buy one from ebay and all i did was call Rogers, gave them the Serial Number and it has been working flawlessly since i bought it. it is a lot cheaper to buy it from ebay then it is to get it from rogers, $180.00 vs 499.00, also when buying on ebay they will give you the serial number prior to placing your bid, this way you can contact rogers to make sure that the PVR can be registered on your account.
#55 |
Thanks for the info. It also looks like you can buy SA3250HDs for around $50 on eBay.
#56 |
upsdriver The only STBs that Rogers will authorize are Rogers units, so the eBay unit you purchased must have been from Rogers originally, in which case there is no problem.
As indicated earlier in this thread, Rogers doesn't activate outside STBs. If you had a different experience and can confirm, we'd like to hear from you, because you'd be the first.
#57 |
Hello,
I'm just wondering if it's possible to use an HD PVR box that has not been supplied by Rogers. When I signed (almost) 2 years ago, they gave me the 8300 HD PVR box free for 2 years. Seeing as the promo is almost expired, I'm not even considering paying $20 per month to use their outdated PVR... anyone know where I can pick up an HD PVR (not necessarily Scientific Atlanta) and if it will even work (would I just have to swap the card or something?)? Thanks for looking!! Martin |
#58 |
There are no third party receivers that are capable nor will rogers allow you to use one on their network.. Your only alternatives are
1) Swapping out your HD PVR for a Standard HD Receiver.. Then go out and buy the Hauppauge HD PVR.. The only drawback with this option is you need a computer. The Rogers HD receiver connects to the Hauppauge HD PVR using component cables.. Then you connect the Hauppauge HD PVR to your computer 2)Switch to a provider that offers more up to date equipment 3) Keep the HD PVR that you currently have and avoid all the hassle it takes to do 1 or 2 |
#59 |
Rogers will not activate "outside" STBs as indicated in this thread to which your post was moved:
There's a thread in the digital deals forum here where you can purchase a new HD PVR for less than 2 years rental cost. See the following post, useful for those new to the forum - FAQs, Search Tips, Optimization, etc: http://www.digitalhome.ca/forum/showthread.php?t=57741
#60 |
My friend wants to send me his 8300 HD from the US. It was programmed to work with Comcast. Is there way to setup to work with Rogers?
Thank you! Last edited by 57; 2010-01-06 at 05:45 PM. Reason: Moved to existing STICKY thread. Read earlier posts & thread title. |
