Any Canadian online store carry HDTV FTA receiver or better with PVR?
JC
Jean Claude |
Kust has the pansat non HD DVR. You'd have to import your on Integra from a US vendoe, I think.
Try http://www.dvbsource.com for FTA satellite stuff. Its a Canadian site.
If you hold out a few months Coolsat has both hd and hd pvr coming out. Just in beta testing stage at the moment so info is hard to come by
Other than that there are no hd fta unless you go the pc route. As for the Pvr, pansat does make a pvr one but its not cheap!
TBD yet again :) |
#5 | |
4DTV DSR922 HDD 200 VC 2+ GI2500R VC 2 Pansat 2500a c/ku/dbs feed 10.6ft Clearview mesh AMC-8 to AMC-12 24"Venture. |
Well from what I heard the next Coolsat which is the 6000 (mid March) is not HDTV so when are they planing to release these HD ones?
Without C-bad there is not really much HD unless you want PBS HD.
I find PVR useless without guide data.
Since PBS is the only HD channel up there it would be crazy for a company to mass produce a HD PVR receiver like that. HD FTA receivers i've seen for $700+ US but hard to find. If a new coolsat is coming it could be a PVR, but highly unlikely an HD receiver. |
#9 |
http://www.coolsatusa.com/ms2000.htm This is the upcoming hd reciever, MS-2010 IP-STB is the hd reciver and MS-2020 IP-STB will be a HD pvr
Bunkhouse you are correct that the next coolsat the 6000 is not a hd just an improvement over the 5000
TBD yet again :) |
#10 |
Is it just me....or does it look like there is an HDMI port on the bottom of the CS 2000?
Doesn't say a thing about that on the site. Just says 2 USB ports and 2 RJ45 connections. Probably a USB....but those bevels................
#11 |
plus it says on their site that it is mpeg2 compatible...hmm...will this be the first HDTV fta
#12 | |
#13 |
The advertisement says it is for IPTV, so I suspect it is not a satellite receiver.
Seems to have the RJ-45 connection for you LAN. |
#14 |
Rumor has it that a Pansat 7000HD is coming, also nuesat http://www.neusatusa.com/index-1.html I guess we will see who comes first and when.
#15 |
Here are the full specs and a good pic of the Pansat 7000 HD
http://www.pansat-7000.com |
