FTA Lnb advice? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Free to Air Satellite Television
Old 2005-12-08, 01:38 PM   #1
bsr2002
Default FTA Lnb advice?
What is the best LNB for a 90cm Dish?
55" Mitsubishi WS-55315
HUMAX HFA 100
CM 4228 (UHF)
Antennacraft CS600 (VHF)
bsr2002 is offline
Old 2005-12-08, 03:09 PM   #2
Danster
Can you get your hands on a Starchoice "flashlight" style LNB? That's what I have on mine and T5 or T6 come in very loud and clear, so to speak. Amazonas also gets in clear.
Home Theatre: Yamaha HTR-6190, Klipsch Speakers, SANYO PLV-Z4, TOSHIBA HDDVD, LG BD555C, Cerwin Vega HTS12 Sub, VIP2300, XBox 360, HTPC.
Danster is offline
Old 2005-12-08, 03:42 PM   #3
prdufresne
So my StarChoice quad-LNB will work fine with FTA?
It's not the heat, it's the humility!
prdufresne is offline
Old 2005-12-18, 11:26 AM   #4
classicsat
Yes. You will need to turn tone on for the "middle" LNBF.
classicsat is offline
Old 2006-01-03, 02:36 PM   #5
prdufresne
Okay,
Double-take.
I just took another look at the dish I have in the garage, and it's a strange beast. It appears to be a dual-lnbf (there are 2 cylindersin a v-shape) with two outputs on each lnbf connected to a 4x2 multiswitch. The multiswitch says it is for "non-stacked" systems.
Would this be considered a Quad-LNBF? I assume that each LNBF only receives on satellite which is why I need the 4x2 switch.
Any thoughts.
Old 2006-03-10, 01:51 AM   #6
crazyone
Default dishes and equipment
I have 2 old primestar dishes with lnb's would these be good to use if I get a FTA reciever
thank
new to all this FTA stuff any advice on equipment would be great
crazyone is offline
Old 2006-03-10, 11:37 AM   #7
Danster
I'm not familiar with what signal Primestar were using. The 2 different type of LNB's are Circular and Linear.
The circular type can be placed with very little orientation on your dish. The linear type, you have to position them in a way that the horizontal signal will be matched with the horizontal input of the LNB (inside). Maybe I'm getting ahead of myself for you here.
Instead, tell us what you have for equipment (if any) and tell us what you really are going after. If you like international programming like Arab, Spanish and many more, a fixed antenna pointing at Telstar 5 at 97 degrees will be good enough. If you want the full meal deal from Amazonas (61 degrees) to the Galaxy 13 (at 127 degrees), you would need a 1 meter dish with a motorized system. Hope this helps.
Danster is offline
Old 2006-03-12, 11:15 PM   #8
crazyone
dont have anything yet except the old dishes with lnb's just thought i might check it out if it wasnt too expensive
thanks
crazyone is offline
Old 2006-03-13, 11:31 AM   #9
tdti1
thank
The invacom QPH031 is a pretty cool lnbf, does linear and circular polarization.
4DTV DSR922 HDD 200 VC 2+ GI2500R VC 2 Pansat 2500a c/ku/dbs feed 10.6ft Clearview mesh AMC-8 to AMC-12 24"Venture.
tdti1 is offline
Old 2006-03-13, 03:12 PM   #10
Danster
You still have to let us know what are your main interest in FTA. Right now, I am watching 2 birds: T6 for Mexico programming and IA13 for Much Music style station in Dolby 5.1 . Like I wrote before, if international programming is what you are after, a fixed antenna on T5 is enough. To get the full meal deal, motors dish and descent box, be prepared to pay at least, close to $500.....
Danster is offline
FTA Forum Sponsor
