Good morning. I'm not sure if this is the right place to post this, but I recently bought a Pioneer VSX-815s reciever. I have the Rogers 8300HD digital box as well. I can't seem to find a code that will allow me to program the AUX key to control my new reciever. Does anyone have an idea? I've tried the 3012 code to no avail....
Thanks in advance! Rib
I'm in no condition to drive...wait! I shouldn't listen to myself, I'm drunk! |
Location: Downtown Toronto, Rogers Cable, SA8300HD, Samsung LN52B750, Pioneer VSX-1019AH, HTPC w/Blu-Ray&HD DV
I have the VSX-1015 version of this receiver (great receiver, btw), and I couldn't get the 8300HD remote working either. Turns out the version of the remote Rogers ships is the low-end AT8400 model with limited peripheral support... Long story short, I bought the "higher end" AT8550 off of e-Bay for $20 and it works like a charm. It changes volume, mutes, and powers off the receiver just fine. There is also an AT8400 Rev B model that may work since it also includes a few more Pioneer codes, but I don't know for sure about that one.
Anyway, hope that helps. |
Try all the Pioneer receiver codes and don't use the "power" button to test. Use something like volume. Some receivers have discrete on/off power and the SA remotes can't do it. I had similar problems with Yamaha until I found that the volume and some of the other functionality was there, just not on/off. (actually I could do off).
I have the VSX515s and I have the same problem - the codes for Pioneer do not work using the AT8400 remote. I heard that Rogers provides a newer 5-device remote so I'm wondering if this newer remote might work with my receiver ? Can I just go to Rogers and ask for the newer remote ?
thanks ! |
I went into Rogers to change my remote for my Explorer3200 and was given the new 5 device remote. The CSR I spoke with said they would even replace the remote if the batteries were dead. Give it a try.
I too just picked up the VSX-516, and have just set up the new remote and it will control many functions of the Pioneer.
Sony KDL-46W5100,Pioneer VSX-516k, Pace RNG200N PVR, Cogeco |
Location: Toronto, Rogers Cable Sony 50" SXRD, SA8300HD 320 GB, SA8300 SD , 2 x SA 3200
Rogers' set-top remotes are made by a company called Universal Electronics.
The following link takes you to Universal Electronics remote "catalog" and you can grab the device codes you need by selecting the remote you have and going into the "device setup" section. http://www.urcsupport.com/# Hope this helps. |
Thanks for the info about going into Rogers for a free upgrade to a 5-function. I've struggled with this for a long time (even bought my new Harmony 720 because of I couldn't control my Pioneer VSX-1014TX with the PVR remote).
AccordCanada |
