How much would/did you pay for OTA? - Page 7 - Canadian TV, Computing and Home Theatre Forums
View Poll Results: How much would/did you pay for OTA?
Less than $100 289 30.65%
$100 to $500 479 50.80%
$500 to $1,000 107 11.35%
The sky's the limit. I need the best! 22 2.33%
I'm broke, you insensitive clod! 46 4.88%
Voters: 943. You may not vote on this poll
Old 2008-09-19, 11:47 PM   #91
recneps77
Was that a typo, or is the compression tool actually $80?!
I thought it was like $10-20...
(I went with pre-fitted connectors since the distance was like perfect for the way my setup was.)
Last edited by Cyclism; 2008-09-20 at 12:51 AM. Reason: Removed unnecessary quote.
recneps77 is offline
Old 2008-09-20, 09:06 AM   #92
jb2008
I'd say the cheaper price is actally for the "crimping" tool which works by deforming the connector over coax cable.
The compression type tool and connectors make a much better termination. Because of the quick payback period of my OTA setup, I thought it was worth it to invest in a good tool.
jb2008 is offline
Old 2008-09-20, 10:05 AM   #93
classicsat
I might pay a $25 premium on a TV, up to $50 for an SD tuner or a PCI tuner card, $100 for an HD tuner (maybe a bit more for a DVR), and maybe $200 for an outside antenna, if there were more or for channels around for me to watch.
classicsat is online now
Old 2008-12-14, 04:09 PM   #94
montery
Default My condo OTA costs
Hauppauge 950 usb adapter ~$100
Zerk Antenna from London Drugs ~$60
I get 3 channels (CTV, CBC, Global) in hdtv. I don't bother with the analogue channels.
The rest of my equipment though, to complete the picture was much more expensive:
Yamaha HTR-6090 Amp $800
homebrew HTPC $600
5 B&W Speakers $1800
Panasonic AX100 Projector $2000
3TB Media Server $800
And just to be silly, 2 years worth of bittorrent downloading @ $57/mo = $1370 ... and thats just to fill up the 3 terabyte media server!
montery is offline
Old 2008-12-15, 07:45 PM   #95
tablo
My cost: Phillips PHDTV1 indoor antenna: $30~40
And that's all I have sony kdl-40s3000 but I already had before going ota. And I now use BEV.
tablo is offline
Old 2009-01-02, 10:15 PM   #96
goforit
Default $250 to get Toronto and Buffalo digital channels from Hamilton mtn.
From Hamilton mtn. I get approx. 20 digital channels some HD- picture quality is unbelieveable in higher transmissions (1080). Much better than analog reception.
Total Cost $250:
2 (two) Channel Master 4221 UHF antennas ($50 each), plus other materials (mast, support brackets, RG 6 cable, coupler, connectors, etc. and labor ($150).
goforit is online now
Old 2009-01-07, 02:17 AM   #97
stampeder
The "Less that $100" count has crept up a bit recently. The "$100 to $500" count has dropped about a percentage point in only a couple of weeks, and the other counts have remained about the same.
I think this is symbolic of the fact that so many urban dwellers can now get Vancouver, Montreal, Ottawa, Quebec City, and Toronto digital stations OTA with an inexpensive indoor antenna. Calgary will be coming online soon in the same fashion. Its also symbolic of the fact that more OTA fans are building their own antennas (make sure its a GH).
Just a reminder to potential voters that the cost figure only includes OTA Gear.
stampeder is offline
Old 2009-01-08, 10:39 AM   #98
mlord
Decent compression tools are widely available in Canada (and USA) for under $30, and often for under $20.
mlord is offline
Old 2009-01-08, 02:38 PM   #99
lubmar
under $100
$25 - 4bay antena
$45 - usb stick tuner
already had pc and cables
lubmar is offline
Old 2009-01-08, 04:34 PM   #100
smiles233
so far
91 = coby hdtv tuner
13 = 50' rg6
4 = splitter
39 = cm4221 coming soon from ace hardware outlet
41 = phillips mant 940 small panel antenna
4 = cable/antenna switch
about 190$ so far and i have to buy stuff to mount antenna most likely....we have alot of snow in upstate ny now so i will try to mount it on the side of my house for now until april/may
smiles233 is offline
Old 2009-01-08, 04:38 PM   #101
bozec75
Default Trying an experiment
Cost: $18.00
I just wanted to see if I could get any channels, and I ended up with 9 digital channels
bozec75 is offline
Old 2009-01-10, 05:30 PM   #102
mjbad2
$2 for Sparklers for metal wire.
$1 for screw/washers.
$1 for UHF/VHF transformer.
Had old piece of cable/wood.
Fantastic reception.
mjbad2 is offline
Old 2009-01-23, 12:42 PM   #103
mkmorris
So far these are my costs (WGRZ and WNYO come in flaky, but should be remedied after I put up the mast):
Samsung DTB-260F (my HDTV ready tv does not have an ATSC tuner) $100
Eaglestar CM4221 Knockoff $36.00
10 feet of 1.25" galvanized fence pole (Home Depot) $10.00
Two pairs of CM 9036 18" Brackets (frankensteining two 18" brackets to make one larger set of 26" brackets) - $87.00 incl Shipping
RG6 - $0.00 (had leftovers from a previous install)
RG6 compression fittings / tool $0.00 (had leftovers)
HDMI/RCA's - $0.00 (had leftovers)
18" Masonry Bit ($14.00)
Wall Plate $1.50
Grounding block from Radio Shack $4.50
Cable from grounding block (free, had some 8 gauge kicking around)
$253.00
I could probably have done it cheaper with only one set of 9036's. But I figured, might as well just have it all delivered to me and save me the time of running around between home depots trying to make an extension.
mkmorris is offline
Old 2009-01-25, 01:17 AM   #104
aforgetit
For my setup I bought 100ft RG6, DB4, and CM7777 pre-amp. Total was approximately $170 CAD and was worth every penny. LCD is not included in cost cuz I didn't buy it for DTV (but to pass down my CRT). After coming across OTA threads my interest was peaked and I looked for a way to increase my channel count over my rabbit ears. I got jealous over how many HD channels people were getting when my lowly rabbit ears were only pulling in 3.
aforgetit is offline
Old 2009-01-25, 06:09 AM   #105
Marc
Mini State Antenna - Free hand me down
100ft RG6 + connectors - $15
CBC English Radio, TV and web streaming.
Marc is offline
OTA Forum Sponsor
