I discovered a glitch in the "VCR recording" feature in the
Motorola DCT 2500 (Digital Cable Receiver) cable box. I'm using Shaw in Lower Mainland of BC. I set the Cable box to record at 12:30am channel 87. I turn it off before the recording time. (I also tell my VCR to tape it at that same time). At 12:30am the cable box turns itself on and goes to channel 87 (GSN). Everything works fine. Both picture and sound working. The glitch occurs if I press any key on the cable box remote control while it's recording. What happens is a small "Mute" word appears at the top of the screen and the sound cuts off. How do I bring the sound back on? I even tried "Continue action, Cancel recording". I then changed channel and played with many menu settings but still no sound! The only way I found to un-mute the sound is to turn the cable box OFF and ON again. Note, that this "Mute" problem only occurs if the cable box has turned itself ON on its own and I press a key while it's "VCR Recording". If the cable box was on already, pressing any key won't mute the sound. Has anyone else noticed this? What could be causing it to mute? I'm sending a copy of this problem to service tech. Tony Last edited by ttony_at; 2005-09-26 at 11:53 PM. |
I still don't have a answer as to why this occurs. The Motorola DCT 2500
isn't suppose to have a mute fuction, so why does it have one? |
Premium Supporter
I am having a similar problem as noted in this thread http://www.digitalhomecanada.com/for...ad.php?t=40884
Glad to see I am not the only one Shawguy |
