9200 not working with HDMI out. - Canadian TV, Computing and Home Theatre Forums
Old 2005-09-25, 10:29 PM   #1
Geoff
Default 9200 not working with HDMI out.
I've recently purchased a Sanyo Z-3 projector and have discovered an unusual problem with the HDMI out from the 9200.
I need to turn the 9200 off and then on again in order for the projector to either sense a signal or for the 9200 to send a signal out of the HDMI out.
Component works fine .
This is very annoying.
I have found others on the web that have had the same problem with different displays so this is not isolated to my projector/9200 combo.
Has anyone else noticed this problem????
Tramps like us...
Geoff is offline
Old 2005-09-25, 11:42 PM   #2
Diamond
I have mine connected via HDMI and have never had a problem. I have had mine since they were first released.
5900 on Sony Trinton 24 inch
6100 on Samsung 53 DLP
9200 on Sony KV34XBR910
Diamond is offline
Old 2005-09-26, 12:47 AM   #3
Geoff
do you have the same projector or are you talking about the 9200?
Tramps like us...
Geoff is offline
Old 2005-10-06, 04:25 PM   #4
Marlek
Interesting... I have the 6100 hooked up to the Z-3 and haven't encountered the problem.
Marlek is offline
Old 2005-10-07, 05:31 PM   #5
dgwhite
Default Off topic but...
How does the Z3 look with the 9200? I have the 5200 and watch it with the stretch. Pic quality is good but the stretch annoys me
dgwhite is offline
Old 2005-10-19, 02:56 PM   #6
Dialdn
I have a similar issue with my set-up I just upgraded my projector from a BenQ 6100 to a Panny PT-AE900U. Everything works fine via Component. But, when I use HDMI, the channel appears, goes black for a second and comes back. This happens each time I change channels or use the PVR to go forward and back.
I spoke to my local supplier as well as Panasonic Canada. It seems to be an issue with the 9200 but Bell won't admit it. It is a handshaking issue I guess. I have read others having similar issues with the Dish 942. The suggestion is that it is a bug hopefully a firmware fix will come out of it.
D
Dialdn is offline
Old 2005-10-20, 01:17 AM   #7
I_Want_My_HDTV
Angry
There are issues with HDMI/DVI devices. I get glitches with the 9200 set to 1080i and a Toshiba TV. I also have a DVI monitor that cuts out with an ATI video card. It can only get worse when HDCP is enabled.
I_Want_My_HDTV is offline
Old 2005-10-20, 07:24 AM   #8
Altaman
Yep had the same problem with an LG upconverting DVD player in that it would not display a picture on my Daytek via DVI. Took the LG back, got a samsung and it worked perfectly. I now have the Samsung hooked up via component and the 6100 hooked up via DVI and they are both working fine.
Alt
Altaman is offline
Old 2005-10-20, 09:26 AM   #9
Dialdn
I am going to get a Sony upscaling DVD player today and will use the HDMI cable for that. I will post if there are any problems.
D
Dialdn is offline
Old 2005-10-20, 01:09 PM   #10
Q
I have had my panasonic S97 dvd player and now my 9200 hooked up to my Toshiba 51H84C HTV with no problems with either.
Q is offline
Old 2005-10-21, 10:55 PM   #11
jvillain
______________
I have a Sony RP and some timesa DVI works and some times it doesn't. I haven't been able to pin point a combination that always work or a combination that always doesn't. Quite odd.
jvillain is offline
Old 2005-10-22, 05:12 AM   #12
Interceptor
My DVI wouldn't work on my 6100 unless I did a reboot every time I started it. Bell told me to leave my receiver on. I got fed up with that and another agent redownloaded my last update and it worked fine until the receiver gave up the ghost.
Interceptor is online now
Old 2005-10-22, 10:25 AM   #13
Battscrew
Location: Calgary, just west of the center of the Universe
I have my 6100 hooked up via DVI for a year - no problems at all. I use a Star something cable from Memory express
Am I getting new Sony?
Battscrew is offline
Old 2005-10-25, 11:29 PM   #14
Dialdn
Just a follow-up.
I bought a Sony upscaling DVD player and sending a 1080i signal to Panansonic AE900 using HDMI. No issues at all. Once again pointing to a small HDMI problem.
D
Dialdn is offline
Old 2005-10-26, 08:18 PM   #15
ksaban
I have the same problem with my 9200 and my Panasonic TH42PD50 Plasma TV.
I have to do a hard reboot of the receiver to get a picture out of HDMI.
If I have my TV running and shut it off, leaving the receiver on, I have a black screen when I turn my TV back on. Seem like it's an HDMI synchronization type issue. I have reported it to Bell Tech support.
ksaban is offline
