9200 / 9242 / 9241 Installation 101 - Page 60 - Canadian TV, Computing and Home Theatre Forums
Old 2006-11-06, 09:23 PM   #886
jonathana
I had left my 3100 in the bedroom unplugged all day and now the signal comes in but very few channels and not all of them have images???
Port 1 2 3
Satellite 91 82 X
Transp. All All X
Device twin twin
Satellite reception verified
Installed switch model DPP Twin
jonathana is offline
Old 2006-11-06, 09:32 PM   #887
Q
what is your signal strength? You should have at least 70 or more.
For missing channels you may have to resend your programming. They now have that option online or call in to bell.
Q is offline
Old 2006-11-06, 10:11 PM   #888
jonathana
i unplugged it a second time and tried it again now the channels seem to be all their, from what I can see and the signal is at 89%... I guess i'll go back to the drawing board for the living room, maybe I connected it too quickly to the dish and didn't do it properly. Is it possible to fry a receiver? I had a wierd smell comming from the 6100 tonight.
Old 2006-11-15, 08:25 PM   #889
westmanguy
Ok quick question. Cords included with the 9200.
I am buying this very soon, but this has to do with installations so:
I have heard HDMI cord comes in the box. What about component video or S-Video? (I need both to connect receiver to HDTV and DVD Player to HDTV).
Does it have the Optical output for audio. Purchased cord online: Toslink Optical cord.
wanting to connect that from receiver to Surround Sound System.
Thanks! - Cheers!
westmanguy is offline
Old 2006-11-15, 09:19 PM   #890
Gillest
Westmanguy,
9200 comes with DVI to hdmi cable (with dvi to hdmi adaptor so you can go hdmi to hdmi if needed). Also included are a set of component cables and also some audio cables (RCA).
The 9200 also has an optical out for audio but no s-video out.
Hope this helped!
Samsung HL-S7178, Panasonic TCP50ST50, OPPO DV-981HD, PS3 40gb, Onkyo TX-SR674, Videotron 8642HD PVR, Harmony One
Gillest is offline
Old 2006-11-15, 09:29 PM   #891
edchen
Originally Posted by ken0042 View Post
There has been a lot of discussion on the 9200 regarding installation; so much so that I've decided to put together this thread. Now, let me start off by saying that I haven't installed a 9200 myself; most of this info has come through my own research and reading online. If you find anything I've put in here to be in error, please let me know so I can make the appropriate corrections. As well, keep in mind these installation instructions are geared towards those of you familliar with the basics of installing satellite dishes.
First commonly asked question is if it can be hooked up using only one of the tuners. The answer to that is no. If you try to do so, you will run into problems. The bottom line is you have to use both inputs on the 9200 for it to function correctly.
Example #1- Installing a 9200 using only 1 cable.
To do this, you will need the following items. A Dish Pro Plus (DPP) Twin LNB, and a DPP Seperator.
You connect 1 RG6 cable to the DPP Twin LNB, run it into the house, and then use the DPP Seperator to seperate the signals into the 2 inputs of the 9200. Your connection will look like this:
Now, some people have asked if they can install 2-9200's in the same house? The answer is yes. Using one more seperator, you can use the extra connection on the DPP Twin LNB and connect them both.
Please note that the 2nd receiver in this example can be any other type of receiver; new or old (Legacy.) DPP will support either. Of course with a single tuner receiver you will not need the seperator on that one.
Does anyone know whether I can use the above suggested setup but instead of getting the twin LNB dish simply use the regular expressvu dish and the SW44.
The set up would be dish > SW44 > one wire to spliter > two wires to dual inputs on the 9200. Any help would be greatly apreciated. Thanks
edchen is offline
Old 2006-11-15, 10:33 PM   #892
westmanguy
Wow thats alot of un-nessesary qouting.
Old 2006-11-15, 10:40 PM   #893
Q
edchen,
the dpp separtor only works with DPP technology. You will need the DPP twin or the DPP44 switch.
Joe
Q is offline
Old 2006-11-15, 10:43 PM   #894
westmanguy
Can someone explain HDMI/DVI thing.
My tv has 2 "HDMI inputs" I am getting it this Saturday at my house.
Will I need HDMI-HDMI input. Will the DVI adapter transformation device degrade anything?
Thanks.
Old 2006-11-15, 11:39 PM   #895
Q
i think HDMI is Hgh Definition Multimedia Interface
I think DVI is Digital Video Interface.
layems terms. They are both the same video quality.
the 9200 included the HDMI / DVI cable for those people with an older set without HDMI and only DVI.
they included the DVI / HDMI adaptor for those people with a HDMI connection.
There is no signal degregation using the bell cable.
Joe
Q is offline
Old 2006-11-16, 06:36 PM   #896
westmanguy
Thanks Q! I ordered the $98 All-in-one package today on the 1-888 number. Got this pack because its half price for 2 months.
Getting the 9200 and standard receiver this Thursday for install.
Hopefully the install will go good.
Also cut the cost $50 by saying get me the rental receiver but I will install it myself (plug in line, call, authorize done).
So all is great, thanks!
Old 2006-11-19, 08:45 PM   #897
Battscrew
Location: Calgary, just west of the center of the Universe
I just noticed that the little yellow/green/blue/red panels lights are not in straight line on the front of my unit. Are all like this or am I a victim of poor aesthetic quality.
Am I getting new Sony?
Battscrew is offline
Old 2006-11-22, 04:58 PM   #898
Terry123
We are getting our 9200 this coming Mondy. One thing I never thought of was the fact that it will be very difficult to run a line from the 9200 in the basement to the bedroom (up two floors). If I ask the installer to go directly from the dish to the bedroom and NOT from the 9200 do I lose any functionality of the 9200? Or is it in my best interest to try and snake the cable from the basement up two floors?
Terry123 is offline
Old 2006-11-22, 05:04 PM   #899
westmanguy
Well, the signal strength of the remote 2 floors up will be of question.
I am sure you can figure away to wire from the 9200 to your bedroom, but... the remote might not get good signal strenght 2 floors up.
Do you have TV on your first floor that you could switch it around, hook it up to the 9200 and put that receiver on your first floor in your bedroom.
Old 2006-11-22, 05:35 PM   #900
Gouie
The lights on the front should be lined up. I suspect your's is defective.
As far as the remote goes, that might be pushing it. Mine is 50ft away and through the ceiling to get to one tv and I have intermitant issues. I would suggest you try to run 2 new lines before the installer comes. Get creative. Is the basement ceiling unfinished or a drop ceiling by chance? I have yet to find a situation where running cable was impossible. Tricky and time consuming yes but never impossible. Don't forget about your cold air return vents. They are a great place to run cable.
Pioneer VSX-1015tx, Paradigm Titans, CC-270, ADP-170, PDR-12, Toshiba 42HL196, Expressvu 9200, 6100, 4100, Harmony 880
Gouie is offline
Tags
9200, 9242, belltv, dpp33, dpp44, expressvu, installation, sw44
