#751 | |
You will also need either DP or DPP lnb(s). In the 9200 package you will get legacy lnb's and the legacy SW 44 switch. None of which will help you. Joe |
#752 |
copper,
hold down the power button until receiver reboots. I have had my 9200 since July I think and I have never had a stutter like that. |
#753 | |
Hope this helps Sam |
#754 | |
#755 | |
#756 | |
Combining 2 cables on Sat 91 and 2 Cables on Sat 82 won't work either. the SW44 can't seperate the odd and even transponders. That's just the way it works. Somehow, i'll just have to run 2 more cables from the dish. Not overly worried though, my VHF/UHF antenna up on my tower does a great job at picking up all the Digital Stations from Buffalo and Toronto so i get High Def anyway through the ATSC tuner built into the receiver. I also asked bell about the pausing of the PVR on playback. He said it was software and should be fixed sometime in April. |
#757 |
wow......you got a good one.
You can still do it with 2 lines but you will need to buy equipment from the states(ebay being the cheapest) as I stated above. Joe |
#758 | |
Sam |
#759 |
Does anybody know what a diplexor is for? I received a couple of them when I purchased my DPP44 switch. I didn't need them for my setup. So I'm just wondering what they're used for.
Thanks Sam |
#760 | |
with the dpp switch you should have got DPP separator's which look like a diplexor but don't work the same way. The separator allows you to run one cable from a DPP twin or DPP 44 switch into the separator which then outputs 2 lines into a dual tuner receiver. |
#761 | |
Sam |
#762 | |
I still have a question though. You mention using Ken0042's Option#5, however that uses 2 dishes and has 4 inputs to the SW44. If I don't have to, I'd rather not install another dish/cables until I'm going HD. My question is:can I continue to use my existing dish with only 2 cables to connect both the dual tuner 9200 and the 3100 using the SW44? All of the diagrams I've seen show 4 inputs to the SW44, and then going to any number of different output combinations, but I'll only have two inputs. My setup is more like the picture Trinitron27 recently posted, with the exceptions that both of my cables would be coming from the same satellite (and then going to 2 rcvrs, not 3). Can I use the included SW44, or do I have to buy a different piece of hardware? Thanks |
#763 |
I don't think you could use the SW44. I know you can use this though.
RCA switch but that's a waste of money. I have an extra one if you really want to go that route. |
#764 | |
Sam |
#765 | |
Well it certainly sounds like I can't use the SW44 as I had hoped. I guess if it's not clear whether the 9200 would work with both inputs coming from the same satellite, the RCA switch may not be a solution for me. It sounds like I need to do some work. Sorry, but one other question: I'm not exactly sure what came in the box (I'm still at work), but I did see an LNB in there. Can I use my existing 46cm dish (which of course is already mounted/aimed/grounded, etc.) and simply add the LNB and cable it into the house, or do I need the 50cm dish and all that comes with it to see both satellites? I know in future I may need two dishes, but at this moment I can't see why I would. Also, the existing dish is mounted on my chimney towards the front of the house, so another dish there wouldn't look too great. Thanks, Steve |
| Tags |
| 9200, 9242, belltv, dpp33, dpp44, expressvu, installation, sw44 |
