Thread Tools | Search this Thread | Display Modes |
#1 | |
I’m all for that. I can give you alot of good input on OTA experiments I’ve been doing to increase gain like my newest experiment with a homemade Balun I'm about to test.. The Balun’s that come with most Antennas have a very high insertion loss on UHF frequencies, up to 80%. It's easy to make your own tuned to just the channels you want with low loss from what I found out. Here is how..
http://www.kyes.com/antenna/balun.html Half Lambda Coax Matching Section calculator, http://n-lemma.com/calcs/dipole/balun.htm |
#2 | |
I thnk UHF wavelengths range from 10 to 100cm (newbie alert, I don't know what I'm talking about here). Would a 20 to 200cm set of antenna elements work better than a 10 to 100cm set of elements or would more than 8 elements get more signal? More length or more elements? Could you build your own 16 or 32 element antenna? You'd have some 'splainin to do to the neighbours if you put up 32 bowties on the back of your house. ;-> I suspect there are only a small number of antenna design experts around these days, but I'll try to find a forum or newsgroup to ask about this. |
The elements are indeed a specific length, and then the spacing between the bow-ties is very specific as well, as is the spacing of the mesh in the reflector.
I bought a book on antenna design from Radio Shack years ago. Not sure where it is, but it's probably in a box somewhere in the house. Um...unless the ex-wife that got box! |
#4 | ||
http://www.hdtvprimer.com/ANTENNAS/16bay.html http://www.hdtvprimer.com/ANTENNAS/32bay.html and make sure you read the part about "why it might not work" to save yourself some trouble. Also I can save you some wandering around the web looking for antenna technology info. This site is packed with everything you need: http://www.hdtvprimer.com/ISSUES/erecting_antenna.html Quote:
#5 | |
It looked something like this... but didn't have such a long boom. It was $9.95 from what I remember and we wired it up with the old flat twin lead.
The edition of the book I have has pictures and part number for currently-available Radio Shack items, but aside from that, I bet they are largely the same. The science really hasn't changed since then.
#8 | |
Had a section on CB antennas too... something else we put up on the roof. Had one in the car... like everyone in 1976 Breaker-one-oh …… XM4252816 is 10-8 10-10 on the side of this one…. Hay good buddy what’s your 10-20 there? Last edited by HDTV101; 2005-06-03 at 10:15 PM. |
#9 |
#10 |
Does anyone have the measurements of the CM-4228?
I want to build one I just need the length of the bowtie and the separation between them. I have seen a picture and I think I can make it. If anybody is willing to take measurements I could draw the plans and directions on how to make it. I have made antennas before but never bowties and I can't find the formula to cut the elements. I also would like to have the separation between elements. Thanks |
#11 |
Telsat if you are in the Markham area feel free to drop by my office.
I have 3 Cm4228 in boxes for friends there you can measure what you need.
CM4228/9521/7775;F.RmJvc70FH96/8300HDPvr/Dish 612;B.RmSam46A650/8300HD;Study LG42PX4D/Xbox360; LG37LC2D |
#12 |
36"x39.5"x5" Just a little too big to strap on my motorcycle when I was in Illinois and saw them on sale for $39 US grrrr
http://www.warrenelectronics.com/antennas/4228.htm Last edited by tricky; 2005-06-24 at 09:54 PM. |
#13 | |
#14 | |
I went to Rona and saw the mesh but it seems that they only sell it in big rolls. I have to shop around I am assuming the size of the holes on the wire mesh to be 1 by 2 inches from the pictures. I would make a 4 elements or 4 bowties antenna to start since I made a bowtie on a piece of wood just to test and got 4 TO stations no CFTO even though it scanned as 9-1 but I also got ABC from Buffalo and the signal was 83%. CBC CFTO no picture CBC French CITY Toronto One ABC Buffalo I can remember the call letters This is with the small bowtie in the piece of wood inside the apartment. I am moving at the end of the month so I have to put it aside for now but the plan is to install an antenna at the new location. Stampeder i will let you guys know as soon as I get into it. I'll try to post pictures. I think this homemade antenna is doable. TelSat |
#15 | |
| Bookmarks |
