Full story here...
Cable wants to drop radio stations May 12, 2005 OTTAWA – The Canadian Cable Telecommunications Association has asked the CRTC to let its members drop FM radio from their carriage requirements. Specifically, the association wants the Commission to repeal section 22 of the Broadcasting Distribution Regulations, which currently require all cable systems to carry every local FM radio signal in their regions on their cable plant. The CCTA says that so few people actually listen to the radio via cable that it’s a waste of bandwidth that could be put to better use… carrying high definition TV for example. MSOs could, if they wished, still carry the stations as digital services, if the stations desired – and deals were done.
When it comes to humility, I am the greatest! |
I listen to Cable FM all the time. Each morning and evening. I would miss it, although I could probably pick up a few stations with a dipole. Can't imagine it uses a lot of bandwidth...
I've moved this thread into the Cable Forum since it's not specific to Shaw.
#3 | |
I would really like to have my local radio stations available on digital. I would definitely listen, since I get pretty bad reception where I am. As for the bandwidth question, it the space used for the FM band take 16 Mhz, which is nearly three analog channels worth, or 30 or so digital, 6-9 HDTV. However, I imagine there would be interference problems with OTA FM signals. Mark |
#4 | |
A simple solution might be to add these channels as digital channels... I'm not sure how much bandwidth galaxie and max-trax use up. If it works for satellite... surely they can make it work for digital cable.
#6 | |
I may have been misreading this sentence and it may have been directed simply at using OTA instead of Cable. Sorry.
#7 | |
Mark |
When I had Shaw Cable, some of the FM frequencies couldn't be heard because of adjacent channel interference. At one time, the Spokane radio stations were clear because the cableco didn't filter the signal, now they all sound quiet and not very clear. Possibly due to the changeover from Cogeco to Shaw in 2000. So, now that I'm using BEV, I've noticed the clarity of the digital radio signals. So, really cable FM isn't a necessity for me anymore.
#9 | |
#10 |
It's times like this I'm glad I got my Sirius satellite radio, man what a good purchase. I used to listen to NPR sometimes on Cable FM, but if the cable companies like Shaw are going to drop it, and Satellite radio isn't officially approved in Canada, this merely reinforces in my mind what a good decision it was to go and buy a Sirius Satellite radio a few months ago.
They can drop the FM if they want, fortunately I'm not stuck listening to that crappy Galaxie/MaxTrax thing that the cable companies have either. |
#11 | |
#12 |
I love Galaxie, it seems to be better than MaxxTraxx atm. Why? More music selection.
#13 |
Location: Calgary, Shaw Digital HD Plus, 3416 & Expander
I wish Shaw carried all the Galaxiw/MT stations....They took at least 1 good one away a year or so ago (swingin' standards) and replaced it with an oldies French station (YECCH). They should give us all 80 or 60 or however many their are.
HOWEVER...I do listen to cable FM. Out sports talk station is available on it, so I listen to that alot. As are some descent Spokane stations, and the Calgary stations in Cable.
SHAW 2012 HD Count: +8 (51 Total not counting SC or SNETWorld) |
#14 |
I've been listening to cable radio for years (Rogers - Toronto) and would miss it. When you live in a north-facing highrise in Toronto, it's not that easy to get a clean signal using an antenna.
I noticed that Rogers stopped publishing their Radio Guide a couple of years ago and wondered how long it would last. Just fired off a complaint to the CRTC. Shame! Last edited by Ex_Brit; 2005-05-18 at 07:57 AM. |
#15 | |
