#961 |
interested to know if you found someone in Burlington... I am in Waterdown and need a rooftop installer as well.
Thanks |
#962 |
Hi,
I am Looking for a Installer for a T.V. Tower or repair of one in the Mississauga, Ontario Area just off of Trustcott Dr. West of Southdown Rd. If you know anyone that does that kind of job let me know and also the phone number. Thank you. I am not sure if this is the Place to Post this. If not can you Please post it in the right location. Thank you. Ted+ |
#963 |
Yep, its just hard to search in there sometimes.
I left one off the list that is worth mentioning: Crescent Television 3033 Marentette Windsor, ON N8X 4G1 (519) 969-1622 Its basically behind Devonshire mall and they have a lot of stock and a wealth of information. .
Windsor:CM4228+4220HD to 1.Samsung LNT3242H+2.AccessHD DTA1080D [RCA DTA800+CM7775+DTB-H260F in storage] GTA:LN40B750 |
#964 |
Folks.....If anyone knows of installers in the Kingston Ontario area, please pm me the info.
Also for those in the area that have an install, what is the by-law when it comes to towers and antenna |
#965 |
Regarding bylaws, check this thread:
http://www.digitalhome.ca/forum/showthread.php?t=85247 If you find out more about bylaws in the Kingston area please add that info that to that thread. |
#966 |
"Channel One Antenna" is an OTA/CCTV installer company that services the GTA and Niagara. Has anyone dealt with them and how was it?
91XG, C5, CPA-19; Denon AVR-1312 |
#967 |
Does anyone know if otacanada in Ottawa is still up and running? I sent them an email but no reply. I'm looking to buy a UVSJ locally for a reasonable price. I can't find any Canadian retailers selling them online, and Solid Signal wants way too much money for shipping.
#968 |
It was mentioned here once before but it bears repeating.
I had Gary Richards from GR Tech assist me recently with a roof top antenna install and pre-amp set up. He spent a few hours helping me get reception of all of the locally available OTA signals and I couldn't be happier with the whole experience. Gary has 20+ years experience in the cable/satellite/antenna industry and so has a wealth of experience. He also was patient enough to listen to my plans (present and maybe future) and make some recommendations regarding setups. He supplied the hardware for the install (antenna & mount, pre-amp and cabling) and his pricing was very fair in my opinion. He mentioned working in all areas of Ottawa as well as some work in Gatineau as well. Contact Gary at: garyrichards221 [at] rogers.com if you have any installation or equipment needs. |
#969 |
Tjones357
Did you find any one ? I am in Brampton area |
#970 | |
#971 |
So the Terk HDTVI on Tiger comes out at $50 with delivery and won't be here for 10 days... does anyone know where else I can get one of these from somewhere in downtown Toronto?
#972 |
Hi all, I'm looking for a recommendation for an installer that will recommend and install an antenna on my 3-storey townhouse in North/Central Mississauga. Great, clear line of sight Southbound, but I've got a high roof line so I need an install for which this will not be a problem. Thanks for the suggestions.
Pioneer Elite PRO-730HD | Elite DV-59AVi | Marantz SR8200 | Mirage OM series | Rogers/Cisco 8642HD, SA4250HD |
#973 |
#974 |
Can anyone tell me if there are any retailer sell the following in GTA (east of Yonge preferably)
- Filter that filtered out 860 Mhz+ (i.e. high rejection at 860+ Mhz, are they called Attenuators?) - Bi directional 4 way splitter (10 - 1500 or higher) - Diplexer (10-860, 900-1500 or higher) Thanks Last edited by elty; 2012-06-09 at 10:20 PM. |
#975 |
elty,
Check out Tin Lee Electronics for the filter. Save & Replay in Mississauga should have the splitter and diplexer (I'm not aware of a retailer that would carry such specialty items in Toronto east of Yonge). Tin Lee can custom build attenuators or low-pass filters with the amount of attenuation required. Though in my opinion, you may want to look at a low-pass filter that includes the 700MHz band (above channel 51), as it will soon be in use for cellular/wireless data.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
