Any way to repair a DCT6208? (E609 error) - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable HD tuner and HD PVR Discussion
Old 2005-09-02, 09:30 PM   #16
DCTGoddess
The DCTs are formatted at the factory, w/ a 'starter' version of the firmware. It gets updated & the software gets loaded when the box gets the 'hit' from the cable co. I also heard somewhere, that the HDD had an atypical arrangement of devisions.
DCT3412 P1:i-Guide:75.59-a25p2-2.s1.r8, F/W:16.53, ST 04.08, Bootcode:05.08
"It's No TARDIS, but, It Gets You There."
DCTGoddess is offline
Old 2005-09-06, 12:16 PM   #17
rickamlin
Default Voltage rating on capacitors
I was thinking about the reply posted regarding the replacement of 630 mf 6.3v caps with 1000 mf 6.3v caps. Don't caps fail because the insulating paper inside fails, and allows a short. Wouldn't a better replacement be a 630 mf 10v, or 25v cap. This would not change the capacitance in the circuit but would beef up the insulating properties and help guard against failure.
rickamlin is offline
Old 2005-09-07, 12:35 AM   #18
WildThing
Hummm. Not sure. That's my friend who decided this. I tought that we must keep the 6.3v
WildThing
WildThing is offline
Old 2005-09-07, 05:12 PM   #19
greg
Nope, the voltage rating on a capacitor is the maximum voltage you can use it for. going higher produces no effect. changing the MicroFarad rating on the other hand could change the circuit somewhat. I'd suggest sticking with 630mF if replacing a 630, unless it's for power filtering (which you can't be sure of).
greg is offline
Old 2005-09-10, 10:43 AM   #20
sgc69
A Note to Rickamlin's Second Last Post
Info for anyone that wants to know? "DCT6208" tried ghosting drive with no luck? Invalid Source Disk
But just installed new drive unpartitioned and works without any work
Original Drive ST380012ACE New Drive ST380011A
I worked for me if anyone has bad harddrive issue or dead box due to this
Shane
sgc69 is offline
Old 2005-11-02, 08:21 PM   #21
easyamp
This maybe a little off topic even though I found this thread while trying to fix my dead box with an e609 code.
There are 4 things that kill capacitors.
1. exceeding the max plate voltage (not working voltage).
2. overheating from external source ie. other componets.
3. reversed polarity (obvioulsy not the case here).
4. excessive ripple current.
The capitance of a capacitor is directly related to plate voltage as well as it's capacitance.
The formula w=v2*c/2
w=storage energy in joules
v=working voltage
c=capacitance
shows that increasing either voltage or capacitance increase's the peak ripple current (the main killer) that a capacitor can handle.
So yes, rickamlin, increasing the working voltage would help as well as increasing the capacitance in one off the four cap killers.
Also the rated 6.3v is a working volatge not max. Generally you can add as much 20% to this number and find the cap's peak plate voltage or electrolyte breakdown voltage.
I found that after my box was unplgged from the cable and wall that it would work again but only for about 10 sec after reconnecting the cable not power??
I stuck it in my fridge for a half hour or so, so far to see if it's a heat issue I'll let you know.I also rent so who cares if I kill it from condensation, it doesn't work now anyway.
Cheers
easyamp is offline
Old 2005-11-21, 05:20 AM   #22
JoeTaylor
Default Re: Capacitors
Hi Everyone,
Im in the Jacksonville, FL area. Have the same problem with the DCT6200 and the error codes. We have Comcast here and the service guy is coming out to "fix" my unit, which means swap it out, as we rent them here.
I saw the same error codes, searched Google and found this board.
Capacitors
As for capacitors, the ones in the photo are "wet" capacitors, IE they are in a metal capsule and the dielectric between the layers of the capacitor is an organic liquid, petroleum or silicone based. What happens is this dielectric leaks out of the tin (its mounted with the seal on the bottom - in the picture). Once the liquid starts leaking, the capacitor fails.
Had a similar situation with an Acura Legend, Bose surround sound. The board with the 4 amplifiers, half of the capacitors failed due to leakage, IE cheaply made capacitors. The fluid was very corrosive/acidic and caused the circuit board to fail. Also, most dielectric fluids in capacitors are know carcinogens.
Just a heads up from an electrical engineer. If you are going to replace them, buy whats called "mil spec" (military specification) capacitors of the same value of micro Farads, voltage equal to or higher than the ones in there. Mil Spec capacitors work over a broader temperature range and seals on them will not fail.
Funny how a 10 cent capacitor can mess things up.
Very Truly Yours,
Joe Taylor
JoeTaylor is offline
Old 2005-11-21, 07:36 PM   #23
WildThing
Originally Posted by JoeTaylor
Hi Everyone,
Capacitors
Very Truly Yours,
Joe Taylor
Hi
Thanks for this useful information. I don't think that my capacitors were replaced by mil spec but I'll know it for the next time (hope not but... we never know).
Yanick
Old 2006-06-08, 12:20 PM   #24
sgc69
Default Thanks for the info!
Replaced all 4 Caps with new 6.3v 680uF, Reciever booted with eb09 hunt fr3 then ' dl waited for 30min then HD Spun up then everything working!.
Thanks Again!
Shane
DCT6208/2005 SW: 73.44 / FW: 10.13 / Bootloader Ver: 3.06 - Cogeco Cable - Niagara Region
sgc69 is offline
Old 2006-06-08, 12:52 PM   #25
WildThing
Thanks Again!
Shane
Glad to hear that!
Wild Thing (Panasonic PT-AE4000U, Pioneer Elite VSX-03, 7 Athena speakers, HSU VTF-3 MKII w/turbo, Velodyne DLS-5000R)
Old 2006-06-08, 01:42 PM   #26
zipix
Default Eb 09
I have the same problem with my Mot 6412/2305. After it boots it locks on FR3, then it downloads, and after it's done it shows Eb 09. I wonder if it's the same problem? Is the layout of the mainboard the same as 6208?
zipix is offline
Old 2006-06-08, 03:34 PM   #27
sgc69
Not sure if it's the same but i'm sure the CAPS will show (view) BAD if you were to take a look. If you own the box? I took side cutters to the grooves in the tamperproof screws on my to open up. then replaced with normal philips after i was done.
sgc69 is offline
Old 2006-06-08, 09:59 PM   #28
zipix
Nope, different layout of the mainboard for the 6412, and no popped caps. Plus no 630 microF, 6.3V caps. Seems like most of them are 10V.
Back to the drawing board...
zipix is offline
Old 2006-06-08, 11:08 PM   #29
big_hitter44
Hey greg,
I have seen a number of times where a manufacturer cheaps-out and uses a capacitor rated too low for the voltage rail. The 6.3V capacitors on this board "may" be used on the 3.3V voltage rail.
While it seems logical that a 6.3V maximum rated capacitor should work on a 3.3V rail in actual fact a safe design is to use capacitors that are 2x the nominal voltage.
When I have seen electrolytic capacitors popped like this it is generally because the voltage rating was inadequate. A 10V capacitor would be a better choice if the voltage across that capacitor is 3.3V.
big_hitter44 is offline
Old 2006-06-09, 01:21 AM   #30
sceott
I have the wame problem with a 6412/2000. I've opened it and briefly inspected the capacitors and could not notice any obviously broken components - does anyone know if the capacitors would show signs of distress (leaking, burn marks, etc) or if they would appear as normal if they are faulty? I don't know enough about electronics to tell a faulty capacitor from a standard one unless it's obvious. I could replace the capacitors haphazardly to determine if that's the problem, but I would probably spend a full day doing that.. Maybe follow the tracelines on the mainboard from the EEPROM to the capacitors, because that sounds like the problem?
Just out of curiosity, do you get any audio/video signal out to the TV while your unit downloads and programs? I thought it was weird that mine sent absolutely nothing to the TV, but maybe that's standard.
sceott is offline
Forum Sponsor
